AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
In Civil 3D 2012 - Style Edit > Display Tab... Can not collapse layer column?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In Civil 3D 2012
See attached image.
This is happening on any object style that I try to edit.
In 2011 and 2013 it displays correctly on the same machine.
Any thoughts?
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
Re: In Civil 3D 2012 - Style Edit > Display Tab... Can not collapse layer co
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Wow, that's horrible. I'm assuming if you move the slider bar all the way to the right you still don't find the end of the Layer column?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I do see the end. And it does display the rest of the columns, but can't slide the column back to normal size.
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
when you slid to the end of the view and saw the other end of the header, did you try double clicking the line to pop it back?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, I tried.
It works fine on the Compnent Type and Visible columns, but the rest are locked down and way, way at the end.
I've tried right-clicking on the column headers, doubleclicking, and sliding. Nothing!
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The 2012 profile style dialogue settings for the columns are stored in the registry here -
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.2
replace <<C3D_ANZ>> with your active profile name.
The key AeccUiPpVbStyleDisplayProps:CListCtrl::1864 stores the values for the columns widths.
On my machine if I set the value to for the key to "0:1:" the column widths reset to the default widths.
If you can access the registry and set the value as above, this may fix your problem.
Of course the usual warnings about backing up the registry apply, etc.
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you so very much Andrew!
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
