• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    AllenJessup
    Accepted Solution
    Improve Error of Closure of Parcels
    150 Views, 4 Replies
    08-09-2012 08:43 AM
    Is there a way to improve the error of closure of a Parcel. I have one Parcel that has an EOC of 0.0161'. That's a little higher than I like to see. I understand that some of this has to do with the precision of the analysis. But with bearings to the second and distances to the hundredth, I'd like to think we could do better than that.
    I suppose that if I changed the POB the closure might improve. But I want the POB to be the closest corner to an existing monument.
    Allen
    Please use plain text.
    Valued Mentor
    Re: Improve Error of Closure of Parcels
    08-09-2012 09:09 AM in reply to: AllenJessup
    How large is your parcel?  The error could be a foot and still be within an acceptable precision if your parcel is large enough.
    *Expert Elite*
    AllenJessup
    08-09-2012 09:44 AM in reply to: stacy.dunn
    That's true. Here is the closure report:
    Perimeter: 1228.61'     Area: 21017.74 Sq. Ft. Error Closure:           0.0161     Course: S47° 58' 56"E Error North:         -0.01080     East: 0.01199
    Precision  1: 76310.56
    The precision isn't that bad. But I usually like to see a closure less than the precision of the courses. I'm not going to obsess over this. But for a proposed parcel I just think it could be better. The closing course isn't within 20° of any bearing or I might try to adjust that leg.
    Allen
    Valued Mentor
    08-09-2012 09:58 AM in reply to: AllenJessup
    It looks like you are dealing with a parcel that has alot of rounding in the annotated calls.  Depending on the number of calls you could see a larger error on a similar sized parcel.
    The only thing you can do to reduce the error is to increase the precision of the courses that are used for the calculation.  This would defeate the purpose of doing a closure report to begin with.
    *Expert Elite*
    AllenJessup
    08-09-2012 10:07 AM in reply to: stacy.dunn
    Yes. It has 12 courses. I'll accept the closure because I agree that increasing the precision wouldn't be appropriate.
    Thanks for your help.
    Allen
