• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Importing .sdf from Hec RAS
    326 Views, 4 Replies
    01-14-2013 01:52 PM
    Greetings,
    I have been trying to import/export information to create a flood map using hec ras. I succesfully (not without some pain), imported the geometric data into HEC RAS and did my analysis. I create the .sdf and try to import it to Civil 3D, but, while it appears to have imported succesfully, it does not show the water lines.
    As a matter of fact, CIVIL3D indicates at some point that the minimim and maximum elevations are both 0.00m.
    I checked the .sdf file, which I attach, and it looks fine to me. It has the information of the water level as it should.
    I think I´ve watched every video avilable and i can´t seem to find the answer.
    Thanks a lot for your help!!!
    Please use plain text.
    New Member
    Re: Importing .sdf from Hec RAS
    01-29-2013 04:30 AM in reply to: JSMoraga
    No help? Did I not explain myself properly?
    Member
    02-21-2013 05:12 PM in reply to: JSMoraga
    I've got the same problem so not sure if you recieved an answer or if anyone can help ??
    Valued Mentor
    02-24-2013 06:40 AM in reply to: JSMoraga
    i have faced some issues with the SDF import in the past and decided to to go the "CREATE PROFILE FROM FILE" route. after i run steady/unsteady state, from the tables window, i save the STA and WSE as a text file, that i can import to automatically create the water surface profile in my stream centerline (HEC-RAS reach) profile view. from there on, i can create the floodplain by stepped offset feature lines, or a corridor.
    sorry, not the answer you are looking for, cannot help much with the SDF.
    Civil 3D 2013 SP1, Win 7-64 bit
    12GB RAM
    Member
    02-27-2013 09:18 PM in reply to: engineer4life1979
    Thanks for the help, I'll give it a go and let you know ! Regards Paul Durrell MIEAust Environmental Engineer Klohn Crippen Berger Level 5 - 43 Peel St., South Brisbane QLD 4101 AUSTRALIA Postal address: PO Box 3276, South Brisbane QLD 4101 AUSTRALIA D +61.7.3004.0278| T +.61.7.3004.0244 | F +61.7.3004.0299 | PDurrell@klohn.com | www.klohn.com____________________________________________________________________________________________________________________________ If you have received this email in error, please delete the original message.
