AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Importing a template?
- Highlight
- Email to a Friend
- Report Inappropriate Content
Is there a way to import a template into an existing drawing?
I created a template, AFTER the drawing was created, and would like the drawing to HAVE that template.
Any way to do this?
Re: Importing a template?
- Highlight
- Email to a Friend
Several ways. The easiest is just insert the template drawing into your current one. (You might want to change the suffix from .dwt to dwg.)
Bill
- Highlight
- Email to a Friend
I did do this, however, will the layers and text style, dim style come with it? I brought it into a drawing that has abunch of other layers and such and I just can't tell.
I am only seeing the layers USED are the ones brought in.
- Highlight
- Email to a Friend
Only layers etc that are referenced by a Style are brought in (I think..!!?!?!) - you can always use Design Center to bring in other content or in 2012 the import styles dialog should do it
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
- Highlight
- Email to a Friend
A good idea is usually to start a new drawing with your template and insert the other one as a block and explode it. Save this new file.
Cansel - Autodesk Division
http://www.cansel.ca/
- Highlight
- Email to a Friend
All the above is great. I would just add one more idea.
If using Civil 3D 2012, check the new "Import styles" feature. It can be very handy to bring in Civil 3D styles and Civil 3D settings from a template or any other drawing.
The command is _ImportStylesAndSettings. You can also find it in the Manage ribbon tab
This feature was also partly implemented in Civil 3D 2011 Subscription Advantage pack under the command _AeccUiImportStylesAndSettings but to a less complete level.
You can also find it in the Toolbox under Subscription Extension Manager>Utilities
Nicolas Menu
Support Specialist, Civil 3D
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
If I explode the block, would it affect the points and contours?
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
The three methods provided all have pros/cons you can work to your advantage.
I use Matt's most. With this method you start with the correct styles, layers, blocks, fonts and dims. When you insert the work as a block, no styles or blocks are over written. Any layers, acad styles or blocks in the work that are not part of the template come along for the ride. This may mess up datashortcuts if object names and object handles change. You could also be inserting corrupt objects.
Neil took the opposite approach which will preserve any drawing specific style overrides made during the design process and datashortcuts. You could also be inserting corrupt objects.
ImportStylesAndSettings as Nicolas mentioned will over write Civil 3D styles. It will not over write blocks, text or dim styles. Datashortcuts are preserved.
C3D 2012, RD 2012
Win 7 64, Core i7,
6 GB RAM, Quadro FX 1700
- Highlight
- Email to a Friend
You need to right click on one of the layouts that are present when you open a new drawing. When you right-click on one of the blank layouts, one of the options states " from template" selecting this will take you to the template files that you create in the options|files menu. The options menu is found by right-clicking and selecting options.
Tom
