• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Peter Funk - Autodesk, Inc.
    Re: Importing Points
    03-29-2005 10:25 AM in reply to: Ernie
    Ernie, You need to strip out the first row of data (or place a # at the start of the row) from your input file. Your input format, Name, Northing, Easting, Elevation and Raw Description will take care of the point names in the first column without a problem. Once the points are imported into Civil 3D, you'll want to make a new point label style that uses "Name" instead of "Point Number". Cheers, Peter Funk Autodesk, Inc.
    Please use plain text.
