• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Importing CTB file?
    15319 Views, 8 Replies
    07-12-2010 07:17 AM
    Ok, I am having a brainfart this morning.. I can't remember how to import a ctb file into my plot settings for a drawing?
    Help please...
    Please use plain text.
    Active Contributor
    Re: Importing CTB file?
    07-12-2010 07:59 AM in reply to: hworth18
    Options ("op"), Files tab, expand "Printer Support File Path", add the folder location to "Plot Style Table Search Path"
    07-12-2010 09:40 AM in reply to: Avera737
    Maybe I should clarify that this is actually a Vendor drawing and I am having to deal with their CTBs. I want to import my own CTB setting into this drawing so I can plot it with my settings.
    *Expert Elite*
    Neilw
    07-12-2010 09:57 AM in reply to: hworth18
    It is not clear what you are dealing with. Are you wanting to create a new CTB to plot their drawing or are you wanting to attach your existing CTB file to the drawing? If your plotter support paths are set correctly you should see your CTB file available in the page setup. If you received their CTB file with their DWG you can copy it to your plot style folder and it will be available in page setup. Another option is to create a shortcut to their CTB file in your styles folder. It will function the same as copying the actual file to the folder.
    If their DWG is set up for STB styles then you will have to convert the drawing to use CTB styles in order to see your CTB tables in page setups. See the help system for the Convertpstyles command.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    07-12-2010 10:06 AM in reply to: Neilw
    Yes, The plot settings shown are STBs, and I was wanting to use my CTB. Thanks, I will take a look at the conversion process.
    *Expert Elite*
    Joe-Bouza
    07-12-2010 10:08 AM in reply to: hworth18
    CONVERTPSTYLES>> yes
    will change ans STB file to an CTB file
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    New Member
    01-29-2013 12:18 PM in reply to: hworth18
    Your help is greatly appreciated. I am also having the same problem importing a .ctb file.
    I already saved the ctb file to the folder as yu directed. When I go to the "plot" command and try to import the new ctb file it does not show in the "add named style plot' window. What to do?
    New Member
    01-29-2013 12:26 PM in reply to: Joe-Bouza
    In reading the dicussion about stb, ctb, etc. I heard that you needed to convert files. What would be the process to convert ctb files  to pcp files? When I try to import the ctb file I already saved in to the plot styles folder the "plot' I can not locate the ctb while in the "plot' command process. I guess I need to convert the file to .pcp so that it can be read. Am I going in the right direction?
    Thank you.
    J
    *Expert Elite*
    01-30-2013 09:15 AM in reply to: jorgelcampos
    When a drawing is opened it will use either a .ctb or an .stb file.
    To switch drawing from a ctb to a stb use the CONVERTPSTYLES command.
    To convert an stb drawing to a ctb drawing use the CONVERTPSTYLES command (same command).
    If you have a ctb file you can convert to an stb file by using the CONVERTCTB command.
    Bill
