AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Imported Google Earth image size not match with imported surface
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Previously i`m using version 2009 and importing google earth image and surface works fine. However, recenty i tried with version 2010 and i`m having some problem here (imported surface / contour seems ok but the image is too large like 3x or 4x). How to solve that?
thanks
Re: Imported Google Earth image size not match with imported surface
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Before importing the GE image, are you sure you set the CRS with _ADESETCRDSYS command..?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
" like 3x or 4x"
If it's 3.28x it could be an imperial to metric conversion problem.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for both of your advice. However, i tried with and without setting the zone and coordinate system and also the units (imperial and metric) all seems to be same. Further, i tried importing the image and surface separately and the result is same if i importing them together. I find the surface is in position and also correct in scale but only the image is too large. Any idea? Nearly give up. thanks again.
