- Mute
- Permalink
- Report
Can someone who has a specific layer assigned for the water drop routine verify if you get the same results.
If I take a file that has the layer assigned (C-TINN-WSHD) and import my template using the "Manage-Import styles" it corrupts the layer to (AcDbObjectId::kNull), then when I save the drawing and reopen it's reset to layer (0).
Pretty obvious but this only happens when "Import Settings" is toggled on, but it shouldn't be corrupting the layer if on.
Both files have the same settings and layers in each, so it's not looking for something that isn't there.
See Image.
EDIT: Just a heads up, I was able re-create this with “_AutoCAD Civil 3D (Imperial) NCS.dwt”
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2026
Win 11 Enterprise, 64-bit
Civil 3D 2026
