Import Styles corrupt layer
klugb
Advisor Advisor
klugb
Can someone who has a specific layer assigned for the water drop routine verify if you get the same results.
If I take a file that has the layer assigned (C-TINN-WSHD)  and import my template using the "Manage-Import styles"  it corrupts the layer to (AcDbObjectId::kNull), then when I save the drawing and reopen it's reset to layer (0).
Pretty obvious but this only happens when "Import Settings" is toggled on, but it shouldn't be corrupting the layer if on.
Both files have the same settings and layers in each, so it's not looking for something that isn't there.
See Image.
EDIT: Just a heads up, I was able re-create this with “_AutoCAD Civil 3D (Imperial) NCS.dwt”
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2026
Win 11 Enterprise, 64-bit
tcorey
Sorry to say, I can reproduce the error. Dang it.
Bug report!
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
klugb
Yea, thought I was going nuts. Kept getting notes that was set to layer 0 but the template has been assigned to thst layer for a long time.
Already submitted to ADSK.
THANKS
Bruce Klug, P.E.
Civil 3D 2026
klugb
Confirmed by Autodesk and reported to development.
Bruce Klug, P.E.
Civil 3D 2026
