• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Accepted Solution
    Import Styles corrupt layer
    165 Views, 3 Replies
    03-07-2013 09:32 AM
    Can someone who has a specific layer assigned for the water drop routine verify if you get the same results.
    If I take a file that has the layer assigned (C-TINN-WSHD)  and import my template using the "Manage-Import styles"  it corrupts the layer to (AcDbObjectId::kNull), then when I save the drawing and reopen it's reset to layer (0).
    Pretty obvious but this only happens when "Import Settings" is toggled on, but it shouldn't be corrupting the layer if on.
    Both files have the same settings and layers in each, so it's not looking for something that isn't there.
    See Image.
    EDIT: Just a heads up, I was able re-create this with “_AutoCAD Civil 3D (Imperial) NCS.dwt”
    Bruce Klug
    AutoCAD Expert Elite
    AutoCAD Civil 3D 2013 Certified Professional
    C3D 2013 (SP1)
    C3D 2014 (Testing)
    Win 7 Pro, 64-bit
    Please use plain text.
    *Expert Elite*
    Re: Import Styles corrupt layer
    03-07-2013 12:16 PM in reply to: klugb
    Sorry to say, I can reproduce the error. Dang it.
    Bug report!
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    *Expert Elite*
    03-07-2013 12:26 PM in reply to: klugb
    Yea, thought I was going nuts. Kept getting notes that was set to layer 0 but the template has been assigned to thst layer for a long time.
    Already submitted to ADSK.
    THANKS
    Bruce Klug
    C3D 2013 (SP1)
    C3D 2014 (Testing)
    Win 7 Pro, 64-bit
    *Expert Elite*
    03-08-2013 07:20 AM in reply to: klugb
    Confirmed by Autodesk and reported to development.
    Bruce Klug
    C3D 2013 (SP1)
    C3D 2014 (Testing)
    Win 7 Pro, 64-bit
