• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    joantopo
    Accepted Solution
    I have a problem with civil 3D 2013+SP1
    343 Views, 6 Replies
    01-25-2013 04:11 AM
    No labels about section data (section views) are displayed. The marks appears.
    I import band set, all layers are activated,..
    With v2012 I didn´t have this problem. In the drawing appears the labels of section data in the section views.
    If I open a drawing made with V2012 in C3D 2013, those labels are displayed.
    Other problem is that I can´t import styles about band set o styles data section from section view. The program say me that it can´t import those styles!!  And two drawings have been made with v2013.
    I have reinstalled the program(C3D 2013 with SP1) again and the problem continue.
    It´s a bug of version 2013?
    Thank you.
    Autocad Civil 3D 2013
    Quad Core Intel i7 3770-cpu 3.40Ghz.
    32gb RAM 1600 Mhz.
    nVidia Quadro 2000.
    Win 7 Pro 64bit
    Please use plain text.
    *Expert Elite*
    Re: I have a problem with civil 3D 2013+SP1
    01-25-2013 04:59 PM in reply to: joantopo
    Post your drawing and let one of us try it out on our 2013 with SP1.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    joantopo
    01-26-2013 04:31 AM in reply to: joantopo
    I've found that if we use this style as default style then displays correctly.
    With the command "create multiple sectionview" indicate the band set style.
    Try to import styles. The styles band set or data section can´t be imported.
    32gb RAM 1600 Mhz.
    nVidia Quadro 2000.
    Win 7 Pro 64bit
    joantopo
    01-27-2013 02:13 PM in reply to: joantopo
    Nobody has seen the drawing?
    I can´t show the labels (data section)
    32gb RAM 1600 Mhz.
    nVidia Quadro 2000.
    Win 7 Pro 64bit
    *Expert Elite*
    01-27-2013 03:52 PM in reply to: joantopo
    Even though the "Weeding" property has been shown in the Sectionview Bands for a number of releases, it was not used when displaying the bands until C3D2013. Your Band style has the weeding factor set to 100, changing this to 0 allows the data to display. You didn't see this issue in C3D2012 since this factor was ignored.
    Not sure about the inability to import the band style or band set, looks like I can import to your drawing, and also import into another drawing from yours.
    joantopo
    01-28-2013 04:22 AM in reply to: joantopo
    if I put the weeding factor set to 0, the labels still do not see them.
    32gb RAM 1600 Mhz.
    nVidia Quadro 2000.
    Win 7 Pro 64bit
    *Expert Elite*
    01-28-2013 06:15 AM in reply to: joantopo
    Changing the Band Set Style will not update existing sectionviews. Recreate the sectionviews and you will see them updated.
