• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    How to rotate point labels on an elevation (facade) drawing?
    136 Views, 4 Replies
    12-07-2012 12:43 PM
    Is it possible to rotate the point labels when working with point files from an elevation Survey in Ciivil 3D? When activating the labels visibility they are horizontal, but when I rotate the drawing  to a side view I am can´t see them.
    So far I was working with Autocad (importing a dxf). Is there a way to rotate at the same time all the points labels, wich in this case are just text items?
    Thank you
    Please use plain text.
    *Pro
    Re: How to rotate point labels on an elevation (facade) drawing?
    12-07-2012 12:51 PM in reply to: rigoleto
    set your point lables to rotate to view instead of object?
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    New Member
    12-07-2012 01:04 PM in reply to: dgordon
     I didnt know I could do that. I guess it is on the menu where you activate and deactivate the labels visibility, isnt it?
    Thank you!!! It will be so helpful
    TRogers
    12-07-2012 01:44 PM in reply to: rigoleto
    It's under the General tab in the point style.
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    BrianHailey
    12-07-2012 07:12 PM in reply to: rigoleto
    If I remember correctly (don't have C3D on this computer) the default point styles that ship with C3D have the label component visibility toggled off in the model view.
    Double click a point style (not label style) in your settings tab and go to the dsiplay tab. Select the pulldown near that top and change the view to model. Is the label component toggled on or off?
