- Mute
- Permalink
- Report
Hi everybody,
I'm trying to model a tunnel network and I have come across a problem I can't solve by myself and any help is greatly appreciated! I know what I'm trying to do is not what Civil is ment for but bear with me 😃
The problem is best described with an example:
A sort of tunnel - or shaft - has to be blasted in order to make an access between the ground surface and a certain parking cavern. This access will be an escalator and the tunnel will be blasted in a 30 degree angle to the horizontal level. Normally when I design tunnel cross sections (CS) the contractor will blast the designed CS perpendicular to the designed profile.
I drew the tunnel CS with sub assembly composer and created an assembly in civil. I then made an alignment and a profile according to our design. And here is the actual dilemma: Civil draws the assemblies so that the assemblies are vertical and what I need is them to be drawn/modelled perpendicular to the designed profile. Is there a way to do this?
I will attach a .pdf and a .dwg of a surface profile along the alignment created (and tidied up) with civil 3d, in which I have tried to illustrate the problem in case my description isn't clear enough!
- Frans
