• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    How to label ditch slope?
    145 Views, 4 Replies
    03-14-2013 07:45 AM
    How do you label the foreslope and backslope of a section? For instance 3:1...
    Please use plain text.
    Re: How to label ditch slope?
    03-14-2013 08:42 AM in reply to: lionel1970
    Does the section segment slope label express as a Run/Rise or Rise/Run?  If it's not the way you want it, you may have to make an expression for it.  Then just add the text ":1" after if in the label style.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    03-15-2013 08:29 AM in reply to: lionel1970
    If the slopes are part of a corridor section, you can apply slope labels to links, based on their code names, in the assigned code set.
    David Zavislan, P.E. | CAD Manager / Associate | NV5 | www.nv5.com
    03-15-2013 08:58 AM in reply to: david.zavislan
    OK, thanks.
    Joe-Bouza
    03-16-2013 04:05 PM in reply to: lionel1970
    Is this a corridor or surface section? If its a corridor, look into the codeset for that link
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
