AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
How to create the surface form contour & extract points from on it
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I would like to create surface from contours and extract points (with value) from on it
I had contours in my drawing; each major and minor contours are single polyline with elevation (Z value).
If I create surface form CONTOUR, some polylines (major or minor) are not included in to surface.
After the creation of surface, I tried to erase the existing contour lines (Polyline) from drawing but the surface will be disappearing.
If I create the surface from ''DRAWING OBJECTS'', I'm not able to select the polylines (attachment 01)
Please advice
Thank you
Najeeb
Re: How to create the surface form contour & extract points from on it
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is it possible that all the contours were included, but your surface style had an large interval that didn't display all the contours? (as in they're part of the definition, just not shown on the screen)
If you change the contour interval to a smaller spacing, do they appear?
ATI Radeon HD 5700 Series
12 GB Ram
i7 920 @ 2.67 GHz
Civil 3D 2011, 2010, 2009 and occasionally 2008 still (unfortunantly)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, now I found my mistake, ![]()
I tried to erase the existing contour lines (Polyline) from drawing but the surface is disappearing. Do I need to keep these polylines in drawing ?
regards
najeeb
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I believe if you right click on the name of the surface in your Toolspace, you can select Create Snapshot that will keep it as it is.
But I would recommend not deleting those lines. Instead I would have a file dedicated to just the Existing Ground Surface (where you would keep the polylines), and then use the data shortcut to bring it into any file that you need.
12 GB Ram
i7 920 @ 2.67 GHz
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Adam, thanks for your quick reply
One more thing, how about the points extracting from contours ?
regards
najeeb
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm not sure what you mean by "extracting points," but it is possible to create points using the surface. Here's a picture how. I'm not sure if you'd want Random Points, or On Grid, but I'm sure you can play with both to figure out what you need.
12 GB Ram
i7 920 @ 2.67 GHz
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Adam, Just need this.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
test
16 GB Ram
120 GB SSD
AutoCAD Civil 3D 2012
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you are adding contour data to a surface, make sure you read this first: http://civil3dplus.wordpress.com/2011/08/13/adding
