• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    najeebcad
    How to create the surface form contour & extract points from on it
    1907 Views, 8 Replies
    07-28-2011 03:56 PM
    I would like to create surface from contours and extract points (with value) from on it
    I had contours in my drawing; each major and minor contours are single polyline with elevation (Z value).
    If I create surface form CONTOUR, some polylines (major or minor) are not included in to surface.
    After the creation of surface, I tried to erase the existing contour lines (Polyline) from drawing but the surface will be disappearing.
    If I create the surface from ''DRAWING OBJECTS'', I'm not able to select the polylines (attachment 01)
    Please advice
    Thank you
    Najeeb
    Please use plain text.
    Valued Contributor
    Adam_Farnsworth
    Re: How to create the surface form contour & extract points from on it
    07-28-2011 04:07 PM in reply to: najeebcad
    Is it possible that all the contours were included, but your surface style had an large interval that didn't display all the contours?  (as in they're part of the definition, just not shown on the screen)
    If you change the contour interval to a smaller spacing, do they appear?
    Windows 7 x 64
    ATI Radeon HD 5700 Series
    12 GB Ram
    i7 920 @ 2.67 GHz
    Civil 3D 2011, 2010, 2009 and occasionally 2008 still (unfortunantly)
    Active Contributor
    najeebcad
    07-28-2011 04:34 PM in reply to: Adam_Farnsworth
    Yes, now I found my mistake, :smileysad:
    I tried to erase the existing contour lines (Polyline) from drawing but the surface is disappearing. Do I need to keep these polylines in drawing ?
    regards
    najeeb
    Valued Contributor
    Adam_Farnsworth
    07-28-2011 04:41 PM in reply to: najeebcad
    I believe if you right click on the name of the surface in your Toolspace, you can select Create Snapshot that will keep it as it is.
    But I would recommend not deleting those lines.  Instead I would have a file dedicated to just the Existing Ground Surface (where you would keep the polylines), and then use the data shortcut to bring it into any file that you need.
    Windows 7 x 64
    12 GB Ram
    i7 920 @ 2.67 GHz
    Active Contributor
    najeebcad
    07-28-2011 05:05 PM in reply to: Adam_Farnsworth
    Adam, thanks for  your quick reply
    One more thing, how about the points extracting from contours ?
    regards
    najeeb
    Valued Contributor
    Adam_Farnsworth
    07-28-2011 05:12 PM in reply to: najeebcad
    I'm not sure what you mean by "extracting points," but it is possible to create points using the surface.  Here's a picture how.  I'm not sure if you'd want Random Points, or On Grid, but I'm sure you can play with both to figure out what you need.
    Windows 7 x 64
    12 GB Ram
    i7 920 @ 2.67 GHz
    Active Contributor
    najeebcad
    07-29-2011 12:15 AM in reply to: Adam_Farnsworth
    Thanks Adam, Just need this.
    New Member
    11-21-2012 11:10 AM in reply to: najeebcad
    test
    Intel i7 3.4 ghz
    16 GB Ram
    120 GB SSD
    AutoCAD Civil 3D 2012
    BrianHailey
    11-21-2012 03:46 PM in reply to: najeebcad
    If you are adding contour data to a surface, make sure you read this first: http://civil3dplus.wordpress.com/2011/08/13/adding-contours-to-a-surface-youre-doing-it-wrong/
