• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    w_davis
    How to create a well-detailed cross section of an Alignment
    160 Views, 3 Replies
    02-04-2013 12:30 PM
    Hey,
    I have been using the "Create Surface Profile" to create cross sections of a road at various points using separate alignments (at the various points).  I was wondering if there was a more sophisticated way to do this?  When comparing my work to other plans it seems that this method is juvenile...Thanks.
    Please use plain text.
    Re: How to create a well-detailed cross section of an Alignment
    02-04-2013 12:57 PM in reply to: w_davis
    Juvenile?   I think you're just using the wrong tool.
    I think what you're looking after is this:  You want sections at an interval, or various places along your road?
    1. Make an alignment of your road
    2. Make sample lines - you can specify where these will fall on your alignment.
    3. Make section views
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Active Contributor
    w_davis
    02-04-2013 01:25 PM in reply to: mathewk
    What is the procedure to make sample lines?
    02-04-2013 01:29 PM in reply to: w_davis
    5 second google search
    http://docs.autodesk.com/CIV3D/2013/ENU/index.html?url=filesCTU/GUID-408653EF-997A-46BD-96A2-40E832F...
    Matt Kolberg
