• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    How to add Gravity Pipe Size to Civil 3D 2010
    146 Views, 1 Replies
    02-01-2013 07:20 AM
    My boss has designed a gravity project that has 21" PVC.  Civil 3D 2010 only has 20" PVC, not 21".  He basically said 21" PVC exists (JM Eagle) so make it happen.  So how exactly can I add a new size to the Parts Catalog under PVC?
    Thanks.
    Bryan
    Bryan Collins
    Cadd Technician
    Windows XP w/ SP3
    Civil 3D 2010 w/ SP3 & SAP
    Please use plain text.
    Active Member
    Re: How to add Gravity Pipe Size to Civil 3D 2010
    02-01-2013 08:05 AM in reply to: bryancollins3174
    Under your "Create Design" tab, go into "Part Builder".  Find the particular part family you're looking to edit, and modify part sizes...
    Right click on "Size Parameters" and select "Edit Values"...
    Select one of the part rows, then using the *New* button in the upper left, click to create a new part.
    Clicking to create a new part actually duplicates that of whatever you had initially selected.  Find the duplicate, and adjust the values desired... Part ID, Wall thickness, Part name, Dia etc.
    Now, you will need to edit your parts list to imcorporate the part size you just created into the current drawing.  It is nested in your toolspace settings tab under pipe network.
    Good luck:smileyhappy:
    ______________________________
    Tyler H. Johnson
    Civil3d 2013
    Dell Precision T3500
    Intel Xeon
    24GB Ram
    64Bit Win7 Pro
