• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Bonsuetay1
    How to Create A Road File From an Object-Pline or Spline
    169 Views, 5 Replies
    09-21-2012 09:34 AM
    Basically I have 3dpolylines and some Splines. I would like to create a road file that uses the geometery of these objects to create a single line/crest of road file.
    Please use plain text.
    *Expert Elite*
    Joe-Bouza
    Re: How to Create A Road File From an Object-Pline or Spline
    09-22-2012 02:10 PM in reply to: Bonsuetay1
    What is a "Road File"?
    If you mean a Profile: You need a 2d horizontal alignments, a profile view and execute the create profile tools to draw the profile.
    If you are looking to create your horizontal alignment from 3d pline and splines. I don't think you can, but you can try to create alignment from objects. Although, I can't imagine trying to tell a surveyor or contractor to build something off a splined alignment.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Active Contributor
    Bonsuetay1
    09-23-2012 03:51 AM in reply to: Joe-Bouza
    A road file meaning an actual file that can be loaded into a Trimble Controller, for survey. Basically we would you this file to "layout" a curve..But it would need to pickup the 3D components of the Splines and 3D Polylines..
    *Expert Elite*
    Joe-Bouza
    09-23-2012 05:47 AM in reply to: Bonsuetay1
    I'm no expert on the survey part but there has to be something in the tool box to export data
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    Active Contributor
    Bonsuetay1
    09-23-2012 05:50 AM in reply to: Joe-Bouza
    oh yeah, i can export the data easy enough, using Trimble link.. It's creating the conent of teh file that is the hard part.
    *Expert Elite*
    Joe-Bouza
    09-23-2012 02:01 PM in reply to: Bonsuetay1
    Hmm.
    I'm surprised one of the survey gurus haven't chimed in. Sinc? Allen?, John?
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
