• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    mattsears18
    How do I create a "no work zone" on a surface
    146 Views, 2 Replies
    03-06-2012 02:22 PM
    I use RocTek for cut/fil calculations, but the program is old and basic, I'm trying to transition to Civil 3D 2012 right now. Typically I create "no work zones" around my building footprints, so that I can do a more detailed take-off in those areas for over-excavations and that sort of thing. Right now I'm using Civil 3D to create an existing surface, a proposed surface, and then a volume from between the two. I thought if I just traced my proposed contours over the existing within the building footprint that I would get what I was looking for. However, analysis of the cut/fill volume shows that there are still some changes being made around the edges of the building.
    Is there a specific way to make a proposed surface, but leave parts of the existing surface untouched?
    See attached photo. The upper middle portion of the screen is where the building is (forgot to turn on layer). You can kind of see how I've run the proposed contours over the existing, however there's still cut areas within the building footprint.
    Please use plain text.
    *Expert Elite*
    Joe-Bouza
    Re: How do I create a "no work zone" on a surface
    03-06-2012 03:26 PM in reply to: mattsears18
    Im not sure if I understand your question, but you can add hide boundaries to the FG surface to not have included in the volume report.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Distinguished Contributor
    03-07-2012 06:23 AM in reply to: mattsears18
    There are different boundary types. Outer, Show, Hide and Data clip along with using destructive and non destructive break lines. If you search for Boundaries in the help they explain them all. To add to the menu,  you can look into masks. This should give you the info you need to do what you need to.
    Bayer Becker
