AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
How can I show 1500 feet of stationing in my plan andprofile sheet?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When I run my production sheets I'm only seeing 1300 feet of my profile and I like to see 1500 feet of my profile at 50 scale. Is there a way to show 1500 feet of profile?
Re: How can I show 1500 feet of stationing in my plan andprofile sheet?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
make the vport bigger
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When I make the viewport bigger, it still shows 1300 feet only. any solutions?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Profile View Properties, stationing tab, toggle to user and adjust stationing as needed.
C3D 2012 SP3
Win 7 Professional 64 Bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks, Jay.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have one more situation, my profiles are setup for vertical 1 to 5 and horizontal 1 to 50., when I run my plan production sheets the profile is showing 1 to 40 scale, my vertical is 1 to 4 in a 50 scale viewport. What I need to do?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No Problem.
See attached to crorrect your H/V scaling.
Enter "5" in Custom Scale field (assuming your keeping the 5 vertical otherwise 10 etc.)
You'll need to make the scales match to match your workflow.
Sounds like either the Plan Prod Layout your using or the Profile View Settings for Vert. scale aren't set properly or both.
A few important things to set properly for this in your dwt's so you aren't changing it all the time:
1. View Frame Group_Commands_Create View Frames_Default Styles_PFL View Style.
2. Choose the appropriate Layout when creating view frames from Plan Prod dwt containing VP set at desired scale.
C3D 2012 SP3
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I check that and the scaling is ok. See at attachment. Thanks
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
the profile is scaling right in the base drawing like it should, just the my plan sheets or not.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Assuming the caption came from te PFL view settings of the plan sheet that's not showing the grid properly then is your viewport scale of the profile set to 1"=40'?
To be clear you desire it all to be at 1"=50' H & 1"=5' Vert. right?
The basics:
Horizontal scale for plan sheets is set by viewport in layout drawings
Vertical scale is set in pfl view settings that are being used.
Please post a caption of the plan/profile sheet if this doesn't help.
C3D 2012 SP3
