• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    sheldon_pardy
    Help with importing contour data from google earth
    1490 Views, 5 Replies
    02-16-2012 01:08 PM
    Hey,
    I need to import some survey data using google earth for a school project. The project involves reconfiguring an intersection. I've managed to import the contour data, along with an image of the area.
    My first question is, if there a way for me to turn the google earth image off in autocad, leaving just the contours?
    My second question is, is there an easy way for me to define the existing road that is in the image? I mean Im going to have to redesign this intersection so I need the existing road to be defined by real lines. The only way I can see to do this would be by physically drawing the road by tracing over the image. Is there an easier, more precise way of doing this?
    Any help would be greatly appreciated
    Please use plain text.
    Distinguished Mentor
    thepworth
    Re: Help with importing contour data from google earth
    02-16-2012 01:30 PM in reply to: sheldon_pardy
    1. set up your drawing with real-world coordinates (state plane ft)
    2. try the command importgesurface with google zoomed in on the area you want the surface for
    2a.  use "coordinate system option"
    3.  no way to get edge of road - you'll have to do it the old fashioned way & "earn it" :smileywink:
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    thepworth
    02-16-2012 09:00 PM in reply to: thepworth
    I was once instructed to set the row/column settings for importing from google earth to have a product under 5000 - i.e. "resolution" settings of 70x70 as 'optimal'.  Can anyone confirm if this is true?  I notice the default now is 100x100.
    C3D 2011
    02-16-2012 10:40 PM in reply to: thepworth
    Last I tried, anything that resulted in more that 5000 points (70*70=4900) GE Import would hang. C3D2012 SP1. This, I have been made aware of, is a Google limitation, not Autodesk.
    thepworth
    02-17-2012 07:05 AM in reply to: Jeff_M
    When I posted yesterday, I'd left the settings at 100x100 and ran the routine.  Took awfully long, but finally came in.
    Since the OP stated they're a student, I didn't mention it earlier, but for anyone looking to interface between c3d or map3d and ge, I'd strongly encourage looking into Plex.Earth:  http://www.plexscape.com/plexearth.aspx
    C3D 2011
    Joe-Bouza
    02-17-2012 02:36 PM in reply to: Jeff_M
    I cant get mine to work above 40, 40?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
