• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Help with conditional subassembly
    189 Views, 7 Replies
    01-08-2013 07:19 AM
    I’m not finding my error.
    I have an alignment running counter clockwise at the perimeter of a septic bed.  I’m trying to use a conditional subassembly for the grading.
    1. From 0’ to 5’ of fill, grade to existing @ 3:1.
    2. Greater than 5” of fill, add a wall (no more than 4’ high) and grade to existing @ 3:1.
    I’ve attached a rel. 13 file for review. There’s something I’m just not getting.
    Please use plain text.
    Valued Mentor
    fcernst
    Re: Help with conditional subassembly
    01-08-2013 12:26 PM in reply to: rwhitlock1
    Not sure. Is this what you are trying to accomplish? Can you throw in a quick hand sketch?
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    *Expert Elite*
    01-08-2013 12:43 PM in reply to: rwhitlock1
    The Layout Grade you specify is only used for display of the conditional subassy in layout mode and is not used in the corridor. Description from Help:
    Specifies the grade of the line that is drawn to represent this subassembly in layout mode. This parameter, in combination with the Layout Width parameter, allows you to position the ConditionalCutOrFill subassembly and subassemblies that are attached to it, but does not display or have any effect in the corridor model.
    What this means is that if you want a daylight slope incorporated into your assy, you need to add it. The conditional cut or fill object does not include this.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    01-08-2013 12:46 PM in reply to: rwhitlock1
    Thanks for your response.
    That’s a piece of the puzzle. I keep thinking I’m missing what should be an easy solution.
    Basically, I have a mounded septic disposal system with perhaps 1.5 ft of fill on the “high side” and 8 to 10 ft of fill on the low. My intention was to apply a baseline around the perimeter of the septic bed. I’d have a mild (5%) grade for  3’ and then, with a conditional subassembly, project grades at 3:1 to existing. The condition subassembly was intended to project grades at 3:1 where the fill slope was up to, but no more than than 5 ft high. Fill slopes of 5 ft to 8 ft would be resolved with a retaining wall of no more than 4 ft in height, then 3:1 to existing ground.
    I’ve tried several iterations of how and where to “stack” the conditional subassembly but I’m just not getting it.
    01-08-2013 12:53 PM in reply to: tcorey
    Thanks, Tim.
    I have a linkslopetosurface assembly included as part of the conditional. I keep thinking my "logic" as to how the subassemblies process is not correct.
    Valued Mentor
    fcernst
    01-08-2013 12:56 PM in reply to: rwhitlock1
    Is this what you are trying to do?
    Ernst Engineering
    Fred Ernst, PE
    01-08-2013 01:11 PM in reply to: fcernst
    Hey, Fred, that is what I'm looking to do while allowing for lesser grade differentials to resolve at 3:1 without a wall.
    The stock conditional subassembly is what I ca't get to do what your image depicts. Was that derived from subassembly composer? If so, I'm curious to know if your configuration could be used as part of a conditional sub.
    Valued Mentor
    fcernst
    01-08-2013 01:17 PM in reply to: rwhitlock1
    No SAC. this is your drawing and assembly.
    Maybe it's just a logic problem.
    Those Conditional Cut/Fill assemblies are really pretty straightforward:
    1. They do the test at their attachment point.
    2. Then if the test is True, for the range of conditions you specified (depth of fill),  the subassembly attached to the end of it is executed.
    You had a 100% slope also for your 4' link...
    Ernst Engineering
    Fred Ernst, PE
