• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    shunter62
    Help page window appeared during a command-won't close
    65 Views, 3 Replies
    01-16-2013 09:53 AM
    I was just editing a drawing, used the Matchprop command, and suddenly the Help was up and an illustration of Mapclean appeared and won't clear, short of closing the drawing altogether. I may have hit 2 keys at once by accident to get this error, but I am not sure. I closed C3D & reopened my drawing, but as soon as I used Matchprop the same thing happened again (this time I did not hit 2 keys). I have this dumb image stuck in the middle of my screen. Has anyone else had this experience?
    I am using C3D 2012 with all service packs.
    Thanks in advance,
    Susan H
    Please use plain text.
    *Expert Elite*
    Re: Help page window appeared during a command-won't close
    01-16-2013 10:03 AM in reply to: shunter62
    Is this an extended tooltip like you get on rollover of a button on the ribbon?
    Does it help to turn tooltips off?
    Do you get this error in more than one drawing?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Active Contributor
    shunter62
    01-16-2013 10:26 AM in reply to: troma
    I don't believe it's a tooltip. It seems to be an image or illustration of a topic in the Help web page (Mapclean was just random, I think). I toggled them off & on with no apparent effect.
    I closed down again & reopened my file, then removed the offending command from the Quick Access Toolbar. Then I replaced the command back into the QAT from the ribbon. Perhaps the command icon got corrupted in the toolbar. So far, so good. Perhaps an electronic hiccup related to the bitmap on the toolbar?
    I'll continue to monitor my drawing & let you know if it happens again. Thanks for the suggestions.
    *Expert Elite*
    01-16-2013 11:50 AM in reply to: shunter62
    I'm in 2011.  If I  have extended tooltips on and I hover over a command button I will first get a textual tip, and then after a few seconds a picture appears.  It sounded like that's what you were getting in some glitchy fashion.
    Hope you don't see it again!
