• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    coburnj
    Help, need to create a boundary around a mass of scattered points...
    575 Views, 17 Replies
    10-28-2011 11:14 AM
    CIVIL3D 2012
    I'm trying to create a boundary (either 2D or 3D polyline) around a group of random scattered cogo points.
    The boundary or polyline vertices needs to be "attached" to, or at least sharing the same x,y,z coordinates as the points that create the perimeter of the group of scattered points.
    The reason for this is to eliminate the lengthly tedeous process of creating a polyline and having to snap each consecutive vertice to the next point on the perimeter of a mass group of points (like 1000's of points).
    I have looked into using the "Shrinkwrap" command, but it's not doing what I need.  It only seems to duplicate an existing polyline that surrounds the group of points, failing to attached to the points on the perimeter.
    Please see attached pictures...
    Thanks for any help that can be provided...
    John
    Please use plain text.
    Re: Help, need to create a boundary around a mass of scattered points...
    10-28-2011 11:21 AM in reply to: coburnj
    if you create a suface based on these points, set the style to show the border, then extract the border of the surface ==> will result in a polyline (would be a 2min way).
    If that's what you look for, ok; if not ... what is the rule to make it better? With "rule" I mean what would be your strategy to get a (for you) better result?
    - alfred -
    Alfred NESWADBA
    Active Member
    coburnj
    10-28-2011 11:24 AM in reply to: alfred.neswadba
    Alfred, thanks for your prompt reply!
    Basically that's exactly what I would like, without having to create the surface.  Possibly a .lsp routine or something to that effect...
    John
    Active Contributor
    mikesmi
    10-28-2011 11:30 AM in reply to: coburnj
    Out of curiosity why don't you want to create a surface?  Is it extremely large?
    Michael D Smith
    Autodesk Application Specialist
    Cansel - Autodesk Division
    "Improving field to finish productivity"
    www.cansel.ca
    Increase your productivity with one of our Upcoming Training Events…
    Active Member
    coburnj
    10-28-2011 11:34 AM in reply to: mikesmi
    I'm looking for the most efficient route possible.  I realize that creating a surface, extracting the boundary and then editing it to fit to my preference is significantly more efficient than tracing the outline perimeter of a mass group of points.  But, I'm reallly just looking to invoke a command that will allow me to select a group of points and have a perimeter boundary created.
    neilyj
    10-28-2011 11:57 AM in reply to: coburnj
    If you are determined not to use the surface method then the easiest manual method is probably to set OSMODE to Node and OSNAPOVERRIDE to 1, this will only let you select the nodes but it could be a bit tedious.
    Another way of approaching the surface method is to create the surface and then add a destructive boundary to delete spurious triangles.
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    10-28-2011 12:47 PM in reply to: coburnj
    Basically there is no built in wlmethod to do what you need. So either you pay someone to create a tool for you (or someone here offers one for free) or you go to the next most efficient method...surface creation. Delete the surface after. Creating that surface is seconds worth of work.
    Matt Kolberg
    http://www.cansel.ca/
    Active Member
    coburnj
    10-28-2011 12:57 PM in reply to: mathewk
    its the editing of the boundary that i'm trying to avoid...the surface boundary works, but there is still plenty editing to do...I agree, it's better than the long manual way...but I need more efficiency...
    Thanks to all who have responded, it's much appreciated...
    John
    Valued Mentor
    TerryDotson
    10-28-2011 01:01 PM in reply to: coburnj
    If you were to consider third party software, we've just added Shrinkwrap Points to the MapWorks Points module.  Simply select the Civil3D points and it instantly generates a 3dPoly.
    Active Contributor
    mikesmi
    10-28-2011 01:02 PM in reply to: coburnj
    Do you use the surface "delete line" command in conjuction with the CP (crossing poly window)  makes for very easy boundary editing.  See example pic where I are editing the boudary in one shot.  No selecting points just removing lines
    procedure:
    select surface
    select edit surface
    select delete line
    type cp at the command line press enter
    create funky shape around surface
    enter to delete all lines touched
    Michael D Smith
    www.cansel.ca
