• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Alan Neal
    Help! What happened to the Grading and layout toolbar? - 1 attachment
    65 Views, 2 Replies
    05-25-2005 03:13 PM
    Please see the JPG file attached and let me know if any of you have had
    this problem. I clicked the little pushpin which is supposed to make it
    minimize. When it did, it minimized the width, and when I click around the
    edges, there are no options to change the window size so I'm stuck with
    this itty bitty window that only shows half of the tools. Has anybody seen
    this or found a fix for it?
    Please use plain text.
    *Alan Neal
    Make sure you don't do this.
    05-25-2005 04:06 PM in reply to: *Alan Neal
    Just a quick word of warning for anyone else who has this problem. It can
    be dupicated simply by clicking the pushpin and moving the mouse away.
    Drag the menubar somewhere to the right half of the screen and voila, the
    pulldown from the pushpin will no longer come down and the width is
    reduced. Click the X and click grading>Grading layout toolspace again, and
    you will get back the tools, but the width is still reduced. Please let
    there be a fix for this. I spent hours customizing. I'm sure it's a math
    error in the X's and Y's and the way it adapts to the screen, probably in
    an editable format somewhere in the program, but I have no clue where.
    Alan Neal wrote in news:4856717@discussion.autodesk.com:
    > had this problem. I clicked the little pushpin which is supposed to
    > make it minimize. When it did, it minimized the width, and when I
    > click around the edges, there are no options to change the window size
    > so I'm stuck with this itty bitty window that only shows half of the
    > tools. Has anybody seen this or found a fix for it?
    > --JivePart=_4a1b8d.0.1567092361553949
    > Attachment decoded: New Bitmap Image.jpg
    > --JivePart=_4a1b8d.0.1567092361553949--
    *Glen Albert
    Re: Make sure you don't do this.
    05-26-2005 04:39 AM in reply to: *Alan Neal
    Alan,
    I was able to reproduce this. That dialog location and size are saved to the
    registry. When you move the cursor over it to select the title bar (when
    it's pinned) it will expands to its correct size so when you move the
    toolbar it saves the location correctly. However, as you discovered if
    you're quick enough you can move it before it expands so it saves the
    collapsed size.
    You can be fix it but it requires you to edit the registry. Are you familiar
    with doing that? From the Windows Start menu, select Run then enter the
    command name Regedit.
    Starting from HKEY_CURRENT_USER, expand the tree to the Profiles key for
    AeccUiDlgGradingLayoutTool. Your acad number may be different, and you
    profile name may be different.
    HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R16.2\ACAD-4001:409\Profiles\<
    Profile>>\Dialogs\AeccUiDlgGradingLayoutTool\WindowPos
    You could also use Find and just search for AeccUiDlgGradingLayoutTool.
    It has a WindowPos key (sub-folder). Just delete it. Next time you run the
    grading layout tool it will go back to the default location and size.
    Glen
