Civil 3D Forum
***Help*** Lost Rotate Point Grips
4 REPLIES 4
dvikse
835 Views, 4 Replies
Can anybody assist in resolving this issue?  C3D '12 Win7-64
Thank you in advance,
Dallsa
4 REPLIES 4
Jeff_M
in reply to: dvikse
If you mean you've lost them in relation to how they used to work, you are right, they are gone. Hover over a grip....
Alfred.NESWADBA
in reply to: dvikse
they are not globally lost and not stolen 😉
They come up if you use the new "multifunctional grips" as they are designed. Click a Civil-point so it is gripped, then place your cursor over one of the cyan-grips and wait for about half a second (without do any more click) ==> wow, you get a popup with the possibilities to modify the object.
And now the bad news:
For AutoCAD-geometry objects you can turn off the new functionality by modifying the sysvar GRIPMULTIFUNCTIONAL, you can decide to use the new method (for a lot of objects) or not.
The bad news are: Civil-objects ignore the setting of the sysvar (at least it looks like it does at the moment/on my current pc), so you have to activate GRIPMULTIFUNCTIONAL or you are not able to rotate anyway. So set it to 3 and have the way now to decide what to rotate, symbol or symbol+text.
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
dvikse
in reply to: Jeff_M
Thank you so much.  Would be nice to have the green grip back, though.
Truly appreciated!
dv
ystillman
in reply to: Alfred.NESWADBA
Thank you, Thank you, it worked!!!
Yvonne
www.PowerCAD.net
C3D ver 2012
Win 7, 64bit
Rail Community
