• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    BrianHailey
    Re: Help About Earthworks Fill
    11-23-2012 09:14 AM in reply to: edgardocalixto81
    Are you trying to get it in 0.15 elevation increments or 0.15 depth of fill over the entire site? If the former, perhaps something like this: http://civil3dplus.wordpress.com/2012/01/26/filling-curve-using-volumes-dashboard/
    Please use plain text.
    11-23-2012 11:53 AM in reply to: edgardocalixto81
    I don't know about tables, but I think this is the best option to get the right contours to display:
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Joe-Bouza
    11-23-2012 12:01 PM in reply to: neilyj
    ohh.. OK good advice
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    11-23-2012 08:21 PM in reply to: BrianHailey
    I have checked the dashboard solution Sir, but unfortunately I already have submitted the areas for fill using the elevation analysis. I can create a flat surface but I could not know the exact elevation in my first layer.
    Please find attached herewith the sample drawing.
    Kindly enlighten me more.
    neilyj
    11-24-2012 03:36 AM in reply to: edgardocalixto81
    Ive not got Civil3D on this computer but a thought of how to get the 0.15 0.3 0.45 etc contours to reflect actual ground level would be to extract the user contours and convert to feature lines taking the levels from the EGL and the raising the feature lines by the appropriate amount e.g. 0.15 0.3 0.45 etc.
    There's probably a slicker way to do this but I haven't though too hard about it......may take a look when next in front of Civil 3D
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
    256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    11-24-2012 08:59 AM in reply to: neilyj
    looking for your utmost idea/s regarding with attached sample drawing Sir...
    11-24-2012 09:05 AM in reply to: BrianHailey
    I am trying to fill the area with 15cm increments Sir. I found your dashboard solution more accurate however I have already submitted the areas for fill with 15cm increments, they now gave a method statement and planning documents with respect to that areas.
    If I will make a flat surface and try to raise it every 15cm starting from the lowest point, my 1st layer of 15cm accummulates different area than my previous areas using elevation analysis.
    Thank you for any ideas you can provide Sir.
    11-26-2012 06:13 AM in reply to: edgardocalixto81
    You seem to be assuming that the 1.35 - 1.50 range area is the lowest portion of the site.
    This is not necessarily the case.  It could be the lowest portion of the existing ground, or it could simply be the highest portion of the proposed ground.  From your sample section it looks like it's a combination of both.
    Are the 15cm lifts of fill necessarily placed horizontally?  If so, it looks like you could have identified your areas wrong.  Cut/Fill contours represent an even amount of cut or fill, but do not represent a horizontal line in real life.
    11-26-2012 06:54 AM in reply to: troma
    So whtaever I find in the Area for elevation banding is totally wrong? We need to place the fill horizontally 15cm thick to justify the specs for our client.
    Any other method how could I do this Sir?
    11-26-2012 06:59 AM in reply to: edgardocalixto81
    See my post in message 12 of this discussion.  That method will generate horizontal contours in 15cm intervals from whatever starting elevation you specify.  In that case you only need to make sure you specify the right elevation to start from.
