AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Help About Earthworks Fill
- Highlight
- Email to a Friend
Are you trying to get it in 0.15 elevation increments or 0.15 depth of fill over the entire site? If the former, perhaps something like this: http://civil3dplus.wordpress.com/2012/01/26/fillin
- Highlight
- Email to a Friend
I don't know about tables, but I think this is the best option to get the right contours to display:
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Highlight
- Email to a Friend
ohh.. OK good advice
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
- Highlight
- Email to a Friend
I have checked the dashboard solution Sir, but unfortunately I already have submitted the areas for fill using the elevation analysis. I can create a flat surface but I could not know the exact elevation in my first layer.
Please find attached herewith the sample drawing.
Kindly enlighten me more.
- Highlight
- Email to a Friend
Ive not got Civil3D on this computer but a thought of how to get the 0.15 0.3 0.45 etc contours to reflect actual ground level would be to extract the user contours and convert to feature lines taking the levels from the EGL and the raising the feature lines by the appropriate amount e.g. 0.15 0.3 0.45 etc.
There's probably a slicker way to do this but I haven't though too hard about it......may take a look when next in front of Civil 3D
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
- Highlight
- Email to a Friend
looking for your utmost idea/s regarding with attached sample drawing Sir...
- Highlight
- Email to a Friend
I am trying to fill the area with 15cm increments Sir. I found your dashboard solution more accurate however I have already submitted the areas for fill with 15cm increments, they now gave a method statement and planning documents with respect to that areas.
If I will make a flat surface and try to raise it every 15cm starting from the lowest point, my 1st layer of 15cm accummulates different area than my previous areas using elevation analysis.
Thank you for any ideas you can provide Sir.
- Highlight
- Email to a Friend
You seem to be assuming that the 1.35 - 1.50 range area is the lowest portion of the site.
This is not necessarily the case. It could be the lowest portion of the existing ground, or it could simply be the highest portion of the proposed ground. From your sample section it looks like it's a combination of both.
Are the 15cm lifts of fill necessarily placed horizontally? If so, it looks like you could have identified your areas wrong. Cut/Fill contours represent an even amount of cut or fill, but do not represent a horizontal line in real life.
- Highlight
- Email to a Friend
So whtaever I find in the Area for elevation banding is totally wrong? We need to place the fill horizontally 15cm thick to justify the specs for our client.
Any other method how could I do this Sir?
- Highlight
- Email to a Friend
See my post in message 12 of this discussion. That method will generate horizontal contours in 15cm intervals from whatever starting elevation you specify. In that case you only need to make sure you specify the right elevation to start from.
