AutoCAD Civil 3D
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Hatch On Its Own Layer
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
264 Views, 1 Replies
09-15-2010 07:02 AM
I want to set the default layer for hatching to a layer called "Hatch". Under Ribbon - Draw - Hatch - Properties, the only option I see is "Use Current Layer" or layer "0". How do I make it go to layer "Hatch".
Re: Hatch On Its Own Layer
Options
- Highlight
- Email to a Friend
09-15-2010 07:35 AM in reply to:
oceanside
Not sure about the ribbon or defaults, but you can create a tool palette that contains your standard object with layer defaults, scales , yada yada.
Create a sample hatch pattern on your standard layer, then drag and drop it on your tool palette. Now you can select that TP and the hatch will be created on your standard layer; even if the layer does not exist in the drawing the tp will create it
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2011
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
64 Bit Win7 OS
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
