• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Hatch Creation Ribbon Contextual Tab Causes C3D 2013 to hang
    134 Views, 4 Replies
    12-16-2012 04:47 AM
    When I try to access a hatch pattern from the Hatch Creation Ribbon Contextual Tab, C3D stops working and I have to force the program to quit.  I've tried repairing the installation, which didn't work.  I've also compeltely uninstalled and then reinstllaed the program, and have applied the Service Pack 1 update, but the problem persists.
    However, accessing a hatch pattern after using the "Hatch" command from the command does seem to work.
    Please use plain text.
    *Expert Elite*
    Re: Hatch Creation Ribbon Contextual Tab Causes C3D 2013 to hang
    12-16-2012 04:52 AM in reply to: ShawnMcCorkle1211
    do you have any custom hatch patterns added (*.PAT)?
    If you start Civil3D with profile "as AutoCAD", do you have the same problem?
    At least I have tried it (with German release of Civil3D SP1) and don't have that issue.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Active Member
    12-16-2012 05:07 AM in reply to: alfred.neswadba
    I have no customized patterns.
    I also have the same issue when running "As AutoCAD 2013".
    *Expert Elite*
    12-16-2012 05:15 AM in reply to: ShawnMcCorkle1211
    if you look to the taskmanager: does AutoCAD (or any other process) need a high kernel-load? Or is the processor at a load of about 0%.
    Another option to try: login to your system with another Windows-user-account/with admin permission/with disabled antivirus .... what happens then when you try to reproduce that issue?
    - alfred -
    Alfred NESWADBA
    Active Member
    12-16-2012 05:29 AM in reply to: alfred.neswadba
    Ok.  I think I figured it out.  One of the patterns had been corrupted.  Once i removed it, it seems to work ok.
