• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Re: Has anyone looked at the Interactive Terrain Shaper?
    06-20-2012 03:02 AM in reply to: tcorey
    I was encouraged to see this as we often need to create an autocad solid from a surface which this does well. We typically use these for imput to other modelling software such as ANSYS.
    However, any surfaces and hence solids it creates are gridded surfaces not the triangulated surface.
    Any idea if it will be possible to output a solid of the triangulated surface or have I just missed something in my quick review?
    Please use plain text.
    Employee
    Smita
    06-29-2012 04:36 PM in reply to: paul.m.graf
    Currently, the gradings can only be converted to a civil grid surface. Such a surface cannot include parking lot boundaries and breaklines because it is gridded. However, this is just a limitation of labs preview and we do want to support conversion to Civil Tin in future.
    Employee
    Smita
    06-29-2012 04:48 PM in reply to: john.chesterton
    The 3d solid created from the model (by switching to solid mode and then extracting AutoCAD 3D solid) is not grid-based. It is a very accurate representation of the solution (and slow due to this reason). The solution is grid-based only as long as you are in the grid mode. Surfaces exported in this mode are also gridded (and hence approximate). (We do intend to support export to TIN in future, as indicated in my previous post.) The moment you switch to solid mode, the grid model is destroyed and replaced with an accurate solid model with hard edges where necessary.
    New Member
    08-22-2012 04:22 PM in reply to: tcorey
    Thanks for the powerful tools!
    Can you tell me how can see only the work canvas instead of the orgin surface  in the right viewport?
    thanks.
    Employee
    Smita
    08-22-2012 04:30 PM in reply to: caishengli
    I assume that you want to turn off the tin surface in 3D. You can set the surface style to not display any components (contours, triangles, etc.) in 3D. Does that answer your question?
    Smita
    New Member
    08-23-2012 11:09 AM in reply to: Smita
    yes,I want to turn off the tin surface in viewport . with your directions I got it .thank!
     can somebody give othe examples of the video? thanks!
    Board Manager
    08-30-2012 04:50 PM in reply to: john.chesterton
    The technology preview has ended. The add-on will stop working on August 1, 2012. Thanks to everyone who participated.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Distinguished Contributor
    10-19-2012 08:23 AM in reply to: scott.sheppard
    What do I need to do to uninstall the ITS from Civil 3d?
    New Member
    01-27-2013 09:59 AM in reply to: tcorey
    I want to try ITS can you provide me the source for it. It would be very much help.
    neilyj
    01-27-2013 11:47 AM in reply to: redangled
    Unavailable as far as I'm aware....
    neilyj
    (No connection with Autodesk other than using the products in the world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
