• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Gravel Hatch
    221 Views, 6 Replies
    01-16-2013 09:59 AM
     I am drawing an area of cobblestone. I am using the gravel hatch pattern and scaling it up. Is there a way to have the hatch pattern close the circles of the gravel peices at the boundary? Or is there another hatch pattern that can do this?
    Please use plain text.
    *Expert Elite*
    TRogers
    Re: Gravel Hatch
    01-16-2013 11:16 AM in reply to: jpc5520
    Usually this is due to being too far away from the origin point.  If you move you model closer to 0,0 and then hatch it, it should look better.  Then you can move your model back to original place is you choose to.
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    *Expert Elite*
    Re: Gravel Hatch
    01-16-2013 11:51 AM in reply to: TRogers
    You don't have to move.  You can just set a hatch origin in the hatch edit dialog or ribbon area.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    *Expert Elite*
    neilyj
    Re: Gravel Hatch
    01-16-2013 11:55 AM in reply to: troma
    changing the hatch origin is definitely the way to go
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Active Contributor
    Re: Gravel Hatch
    01-16-2013 01:49 PM in reply to: jpc5520
    Thank you for the origin tip.
    But, I what I am looking for is at the border/boundary of the hatch area, I would like full "circles" representing the gravel/cobblestone. Now, the gravel/cobblestone look as if a knife cut away the area beyond the boundary. I would like to have the hatch patern look as if someone layed the stones down in a square.
    Active Contributor
    Re: Gravel Hatch
    01-16-2013 02:26 PM in reply to: jpc5520
    I don't think that would be possible with a hatch. You might have to draw a single stone at the proper size and then use the array command to get what you're after.
    *Expert Elite*
    Joe-Bouza
    Re: Gravel Hatch
    01-16-2013 04:25 PM in reply to: jpc5520
    The best I can come up with is: over hatch and polyline clip the patter to show the whole cobble?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
