• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Grading groups and sites
    78 Views, 3 Replies
    02-27-2009 07:48 AM
    Is there a way to have multiple sites in a single grading group? I am trying to add a new site to the surface I have already created but when I try to create grading with the new site it asks if I want to create a new grading group. I would like to keep both sites in the same group/surface so that it is easer for calculating volumes.
    Please use plain text.
    *neilw
    Re: Grading groups and sites
    02-27-2009 07:55 AM in reply to: cory
    You terminology is not making sense. A Grading
    Group can belong to a Site but not the other way around. A grading group cannot
    belong to 2 sites but you can have multiple grading goups in a
    site.
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Is
    Active Contributor
    02-27-2009 08:07 AM in reply to: cory
    OK, what exactly is a grading group? I thought that it was basically a surface? I want to be able to separate different areas of a surface. I would like it if I could grade one area of a surface and not have the TIN lines interact with other areas of a surface. Example: Is there a way to grade a detention pond on a surface and also grade a parking lot on the same surface with out the TIN line being linked together?
    *neilw
    02-27-2009 08:49 AM in reply to: cory
    A grading group is a group of grading that make up
    an object. For example a pond can be made up of several gradings that together
    form the pond. A parking lot can be made up of several gradings that form the
    parking lot. A grading group can be used to create a surface by toggling on the
    Surface settings in the Grading group properties. The surfaces are dynmically
    linkwed to the grading group so any changes to the gradings in the group will
    update the surface.
    Each surface can be independent if the grading
    groups that form them are on different sites. In your example, if you put the
    pond grading group and the parking lot grading group in sperate sites they
    won't interact with each other.
    OK,
