• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D
    *Ernst, Fred
    Grading Targets
    156 Views, 6 Replies
    10-14-2003 11:13 AM
    It says in the Grading Help that a target can be a feature line or the base
    line of another Grading. How do you set these types of targets for a
    Grading in the new interface? I do see the standard target options of
    Distance, Surface and Elevations.
    What I am hoping we will eventually have here is the ability to have the
    Grading adjust the vertex elevations of a target line relative to the
    baseline of the Grading to effect one's desired slope between the two. Or
    vice versa, have the Grading adjust the baseline elevations relative to the
    target line to achieve the desired slope between the two.
    In LDD, I use the folded plane technique of grading, in order to extract
    surface elevations at each breakline vertex of a meandering target line
    relative to a baseline that the surface projection is created from. Of
    course, I would like the new grading to do this in the background now.
    Fred
    Please use plain text.
    *Albert, Glen
    Re: Grading Targets
    10-14-2003 09:28 PM in reply to: *Ernst, Fred
    Fred,
    That didn't make it into this preview release. That help file comment must
    have been missed when we pulled it. ( Grading is the most incomplete
    component in the preview. It got a later start then most, as it required
    some of the other components to be working before much could be done and it
    has some fairly complex issues to solve.)
    When it gets implemented you will be able to grade to a feature line, a lot
    line or an alignment. One criteria option will be to use the elevations of
    the target so that the slopes will vary. There are also the criteria options
    to grade by slope, elev or relative elev. These options will set the
    elevations on the target feature.
    The reverse isn't in the spec. Grading control always goes from the base
    line to the target line. I'll add to to the wish list. I might be able to
    come up with an edit command that would allow you to edit the target line
    and adjust the base line elevations for certain types of criteria. For
    example, slope to a distance would be possible but slope to a surface
    wouldn't be.
    I'm not sure that I understand the folded plane technique, could you
    elaborate.
    Glen Albert
    Software Engineer
    Autodesk Civil 3D Team
    "Fred Ernst" wrote in message
    news:9E15C9F9E054ED091BE6D4C121409586@in.WebX.maYIadrTaRb...
    base
    the
    > Fred
    *Ernst, Fred
    Re:
    10-14-2003 11:03 PM in reply to: *Ernst, Fred
    Hi Glen,
    I've inserted my comments below:
    Actually, we have slope criteria to meet, and need to change elevations of
    the feature line or the baseline as we move through the grading of the site.
    > wouldn't be.
    I say "slope to a feature line target" is what we need. The ability to
    adjust the feature line elevations while holding the baseline elevations,
    and vice versa, holding the feature line elevations and adjusting the
    baseline elevations to achieve the desired slope between the two.
    Still need Regions also, for example, Region 1: 10:1 slope between the
    feature target and base for 50' along the baseline; then Region 2:, 4:1
    slope slope between the feature target and base for 125' along the
    baseline,; etc., etc...
    > elaborate.
    Sure. Say you have a commercial parking lot, and you have a valley pan going
    down the middle. All around the perimeter of this parking lot you have a
    meandering, sinuous, outfall curb and gutter. Now you want the flowline
    elevations of that curb and gutter to be everywhere 2% from the valley pan
    axis. So, using the 3D polyline of the of the valley pan axis, create 2
    breaklines on either side of it at 2% out past the parking lot perimeter, to
    create a large folded surface that fully encompasses the parking lot's curb
    and gutter. Turn the curb and gutter into a 3D polyline and extract surface
    elevations from the folded surface into the 3D polylines vertices.
    Another example, say you have a property line where you need to hold
    existing elevations. Then you have a meandering feature line upslope from
    this inside your property, maybe an edge of walk. Now you want a 4:1 slope
    everywhere between the property line and the edge of walk. So using Create
    Curb, you offset that 3D polyline representing the property line elevations
    at 4:1, and some distance past the edge of walk, create the surface, then
    extract the edge of walk elevations.
    I use this techinque all over a site to establish the desired slope
    relationships between "baselines" and "target lines". Now, I hope the new
    Grading will save me the steps of creating these surfaces used for elevation
    extraction.
    Fred
    *Albert, Glen
    Re:
    10-14-2003 11:56 PM in reply to: *Ernst, Fred
    Fred,
    See below ;
    of
    site.
    Grading from the baseline to the target feature line at a slope will be one
    of the options. The elevations on the target feature line will be determined
    by the slope coming from the elevations on the base line. So that should
    meet your needs there.
    to
    line
    > > wouldn't be.
    Editing the baseline elevations and having it adjust the target feature line
    elevations is easy and will be supported. The reverse is what I've added to
    the wish list. I think I can come up with an edit option to do this, editing
    the target feature line to adjust the elevations of the base line. It would
    only be able to work with grading where the target doesn't move when editing
    elevations - that is grading to a distance or feature ( feature line, lot
    line, alignment).
    Transition Regions aren't complete, but when they are they will support what
    you are asking for.
    > > elaborate.
    going
    to
    curb
    surface
    With grading to a target feature line you will be able to do this, but there
    will be issues we'll need to sort out. In particular, grading beyond the
    ends of the valley pan baseline.
    Here is a simple example;
    You have a rectangle that represents the parking lot perimeter, from 0,0
    to 100, 50 (x,y). The base line runs from 25,25 to 75,25. If you grade from
    the base line at 2% to the parking perimiter. Grading to the lower side of
    the base line it will intersect the curb from 25,0 to 75,0 and grading above
    the base line will intersect from 25,100 to 75,100.
    It would be easy for me to project 2% radially from the ends of the baseline
    to intersect the target at the ends but I don't think that's the way you
    would want it to work. I would assume that you are looking for more of a
    mitered corner affect with the flow direction prependicular from the
    rectangle edges.
    elevations
    elevation
    > extraction.
    You will be able to grade from the property line to the edge of walk at 4:1
    so that the walk way elevations are determined by the slope from the
    existing elevation at the prop line. Another method, if you are trying to
    set a specific profile to the walk would be to grade a sufficient distance
    from the walk toward the property line (say @ -6%), then grade up from the
    property line to distance beyond the walkway. If they intersect, the
    gradings will get trimmed and you will get a feature line in between the
    property line and the walk way where the gradings meet.;
    Glen
    *Ernst, Fred
    Re:
    10-15-2003 12:47 AM in reply to: *Ernst, Fred
    one
    determined
    Yes that will.
    line
    to
    editing
    Great.
    >It would
    editing
    > line, alignment).
    Yes, exactly.
    what
    > you are asking for.
    Great.
    baseline
    > rectangle edges.
    No radial would be fine, because mitered would create a crease where we
    would need a pan to protect the asphalt. We would want to extend the pan for
    cost reasons only to the point where we can't create that radial slope
    condition for sheet flow.
    4:1
    Are you saying the Gradings will trim themselves automatically? That would
    be great.
    Another question: Can you add a radial region to the Grading object?
    Example, say between the property line and the meandering walk , I want a
    4:1 slope up from the property line, then break to a 10:1 slope to the walk.
    You could do it with two Gradings and have them trim themselves, but it
    would be nice to do it with one Grading. Now in LDD, you have to do it with
    the High\Low Point routine to find the break location. I've actually written
    a routine that finds the High\Low on a 3D Polyline using the endpoint
    elevations. So now I draw all these perpendicular 3D polylines between the
    baseline and target line, run my routine, and it places a new vertex at the
    required gradebreak location and linearly adjusts the rest of the vertices
    for each radial polyline. All of these radial polylines between the baseline
    and target line look like a Grading object, just with a gradebreak somewhere
    along them. Actually to have the capacity of 2-3 of these radial regions at
    some point would be nice. You could just toggle them off if you don't want
    to use them.
    So in the end, will these Gradings adjust relative to each other based on
    their established relationships if a change is executed on one? Will they
    have to be in the same Grading Group, Site or both to change relative to
    each other?
    Fred
    *Albert, Glen
    Re:
    10-15-2003 02:36 AM in reply to: *Ernst, Fred
    Fred,
    > be great.
    Yes. Currently intersection trimming only works between gradings in the same
    group but I think we'll need to expand it to optionally trim intersections
    with gradings in other groups.
    walk.
    with
    written
    the
    baseline
    somewhere
    at
    > to use them.
    Not with a single grading object. The approach we took was that you create
    one grading from the walkway and one from the property line and if they
    intersect they will create the high/low ridge feature line. Then, if either
    the walkway or the property line is edited it will recalculate the high/low
    intersection feature line.
    But we should have the capability to more or less accomplish what you
    describe at some point in the future. It requires some additional control to
    feature line elevations. In particular, the ability to define a high/low
    elevation point between two elevations on the feature line and have it
    adjust if the elev at either end is edited, or if either grade is edited.
    With that you would be able to draw your connecting perp lines as feature
    lines, and on each one define the two grades that define the high point
    location.
    Within a site, all feature lines that have a common point will share the
    elevation. What that means is, if you step along the base line and edit an
    elevation, the radial line elevation will also change which would update the
    location of the high point on that radial line (if and when the high/low
    capability is added to feature lines).
    In between the radial lines you would insert Fill gradings. I think I need a
    better name for it because it could be confused with fill slopes, but a Fill
    Grading is one that is not controlled by grading criteria. It is used to
    fill in holes - areas that are completely bounded by feature lines.
    > each other?
    Yes, if you edit the base line it will update all gradings that are attached
    to it. Since you can grade from a resulting target line, those gradings will
    update as well and it will ripple down to all connected gradings. It will
    then recalculate the intersections and clean them up.
    All related grading work has to be within one site.
    Grading groups are named collections to make it easier to organize them and
    do operations such as create surface. A grading can only be in one group,
    but there is no restriction on how gradings are organized into groups.
    Individual gradings can easly be moved to other groups as desired. The one
    limitation is with the intersection cleanup. Gradings only clean up
    intersections within the same group. I plan on adding an option to each
    group to select which other groups you want it to intersect with.
    Glen
    *Ernst, Fred
    Re:
    10-15-2003 04:01 AM in reply to: *Ernst, Fred
    That all sounds very much on the mark Glen. I would just end saying to make
    all your hard work really viable, we need only two Feature\Base line linear
    tools: 1) the High\Low we've talked about and, 2) Set Grade between two
    vertices and linearly adjust all the vertices in between the two.
    I've written both of these in VBA for 3D polylines. Each routine pops up a
    dialog box with two Input boxes showing the endpoint elevations, an Input
    Box showing the current 2D slope of the polyline (2 slope Input boxes for
    the High\Low routine). By changing a value in one Input Box the others
    update. Uneditable Label boxes show length, and on the High\Low routine,
    distance to the gradebreak
    I also use some of Dotsoft's polyline tools such as Proportional Slant,
    where you can graphically pick the vertices you want to use for Start and
    End, and then it linearly adjust the vertices that lie between. My tools
    don't have the ability to pick internal Start and End vertices like Terry's.
    At this point, I'm just afraid all your good work developing the Grading
    relationships will be hamstrung by not being able to manipulate the
    baselines\feature lines with these types of linear tools. We would have to
    explode the feature line or Grading, manipulate with the linear tools, then
    redefine all the relationships again.
    Fred
