• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Jorge
    Grading Layout tools target value
    97 Views, 5 Replies
    01-04-2005 08:10 AM
    How to change in " Grading Layout tools " The target value ? Distance to Surface Thx
    Please use plain text.
    Employee
    Re: Grading Layout tools target value
    01-04-2005 08:22 AM in reply to: *Jorge
    You will need to alter the grading criteria, under the settings tab in the toolspace, expanding grading, then expand criteria sets. Under standard sets you will find the standard criteria you are using. You can then right click and choose edit.
    *Jorge
    01-04-2005 08:42 AM in reply to: *Jorge
    Is locked. I can´t move it. "nzeeben" escribió en el mensaje news:11195216.1104855768443.JavaMail.jive@jiveforum2.autodesk.com... > You will need to alter the grading criteria, under the settings tab in the toolspace, expanding grading, then expand criteria sets. Under standard sets you will find the standard criteria you are using. You can then right click and choose edit.
    Employee
    01-04-2005 09:32 AM in reply to: *Jorge
    Your picture is of the grading layout tools dialog. You need to access the settings from the settings tab of the toolspace. You will then be able to adjust if a value is locked or unlocked.
    *Jorge
    01-04-2005 09:49 AM in reply to: *Jorge
    The problem was the dwg. I Have try with a new one and everything ok. Thanks a lot :-) "nzeeben" escribió en el mensaje news:5253555.1104859955772.JavaMail.jive@jiveforum2.autodesk.com... > Your picture is of the grading layout tools dialog. You need to access the settings from the settings tab of the toolspace. You will then be able to adjust if a value is locked or unlcoked.
    Employee
    01-04-2005 09:52 AM in reply to: *Jorge
    No problem
