• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    lohrmach
    Grading Edit - modify start/end points along grading feature - possible?
    256 Views, 4 Replies
    09-09-2009 12:27 PM
    I am using Civil 3D Grading to grade a lagoon / landfill closure.
    From what I can tell, it appears that the Edit Grading tool only allows me to edit the Distance and the Slope of the grading element.
    But I want to modify the Start and End points that I graded.
    I want to modify this as opposed to deleting everything (all my graded elements) and starting over because this feature line, and the grading objects on it, run around most of the outside of the landfill and much of it I want to keep as is. This is going to be a lot of extra work if I can't edit or trim the gradings.
    I tried breaking the original Feature Line, but I got the error message that graded feature lines cannot be broken.
    Disappointed at apparent limitations.
    Lohrmach
    Please use plain text.
    *Matt.Anderson
    Re: Grading Edit - modify start/end points along grading feature - possible?
    09-09-2009 09:15 PM in reply to: lohrmach
    In most cases, select the grading, and grab the grips at either the
    start or end of the grading object and drag it along the top
    featureline. The Edit Grading is intended to provide the ability to
    edit the Grading objects projection methods.
    Matthew Anderson, PE CFM
    Neilw
    09-09-2009 09:51 PM in reply to: lohrmach
    This screen recording should help you see how it is done.
    http://screencast.com/t/UAznGZxdji
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    Distinguished Mentor
    09-09-2009 10:14 PM in reply to: lohrmach
    If the grading has been applied to a closed feature line here's a way to get the gripable ends like Neil and Matt mentioned: http://civil3dpedia.com/2009/09/09/grading-edit-adjust-entire-length/ Edited by: Civil3DReminders on Sep 9, 2009 10:15 PM
    *neilw
    09-11-2009 09:25 AM in reply to: lohrmach
    That's a handy little trick Christopher.
    __________ Information from ESET NOD32 Antivirus, version of virus signature database 4416 (20090911) __________
    The message was checked by ESET NOD32 Antivirus.
    http://www.eset.com
