• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    johnm
    Re: Grading Contours not true to slope values
    02-19-2013 07:30 AM in reply to: Joe-Bouza
    "Wow ! So now we need a projection grading that finds the first contour then turns to be perpendicular to it?"
    Apparently those contours are also going to need some legal advice aas well. :smileysurprised:
    If anyine in this office or a reveiewing agency complained about contours being spaced 9.7' to 10.7' when it should be ten feet I would first need to contain the laughter, next advise them that their scale may need to be calibrated (holding in the laughter once again) and then remind them that the contours are only accurate to 1/2 the interval so with +/- 1 foot, 9.7' and 10.7' are really 10 to 11 feet and I meet the grading criteria.
    :smileyhappy:
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    Please use plain text.
    Valued Mentor
    fcernst
    02-19-2013 07:54 AM in reply to: johnm
    John you have to keep up with us now...  It's not a question about contour construction. The C3D contours are correct as constructed. That's been established. Grab some coffee.
    It's a question of whether the designers are aware the projection slope used in the C3D routines does not necessarily determine the surface slope. The OP mentioned in Section we typically  show a 2:1 max and the intent is to not exceed that for surface slope per code, but in many cases the resultant surface slope is steeper than that.
    Hailey had a question about slope labeling precision not contour construction.
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    johnm
    02-19-2013 08:23 AM in reply to: fcernst
    Oh Fred my laughter from this thread woke me. I understand exactly what is being discussed. I am just not sure if the issue is more funny than the indignation. :smileyhappy:
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    Valued Mentor
    fcernst
    02-19-2013 08:38 AM in reply to: johnm
    ??? Your post talks about contours not being accurate.
    The legal I'm talking about, is the expert demonstrating for the other side, that the design surface slope exceeds code.
    Ernst Engineering
    Fred Ernst, PE
    02-19-2013 12:22 PM in reply to: Joe-Bouza
    Joe mentioned a grading 'finding the first contour and then turning perpendicular'.  Sounds awkward of course.
    But in message 14 on this thread, Brian reminded us how to add vectors.  Kudos to Brian.
    So, what is really needed (or at least wanted by some) is the ability of the grading slope to subtract vectors.
    Let me put it to you this way:
    Say, within the grading settings there was an option you could turn on and off, lets call it "Remove Parent Object Slope from Grading"
    When turned on, this setting would subtract the vector of the slope of the parent feature line from the required slope of the grading; thus resulting in a true slope of what the user inputs.
    Would you object to such an option?
    Would you use it?  Why, or why not?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    02-19-2013 12:39 PM in reply to: troma
    Just for the sake of stirring the pot, this topic was covered quite well.....7 years ago.
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Create-slope-perp-to-contours/m-p/1849529#M34354
    I had thought there was another, similar, thread that James Maeding had started, but I could not locate it.
    Valued Mentor
    fcernst
    02-19-2013 12:43 PM in reply to: troma
    No, because it would be utterly meaningless. This thread should have been over after Message #3:
    Is your feature line sloped? Grading occurs perpendicular from the feature line and not from the contours.
    Ernst Engineering
    Fred Ernst, PE
    Valued Mentor
    fcernst
    02-19-2013 01:03 PM in reply to: Jeff_M
    This doesn't really stir anything up. Engineers need to evaluate the surface gradient (normal to contours) for geotech slope stability and code items. Code items and design criteria based on free body diagrams of people and cars sliding around.
    Code items such as ADA, handicap parking areas can not exceed 2% in any direction (resultant), in Colorado we can't have greater than 4% in any direction (resultant) in parking lots due to ice.
    Surveyors and contractors want offset staked. Engineers have to make sure everything is safe when things are offset staked.
    What's to stir up?
    Ernst Engineering
    Fred Ernst, PE
    johnm
    02-19-2013 01:14 PM in reply to: fcernst
    I agree Fred and forgive me for being rude before. If the model exceeds the max slope I just back down the grading criteria from 1:2 to 1:1.9 and move on. If contours seem spaced to tight I'll do the same. I might even just through a txt string into a profile, section or plan calling out a max. slope ignoring the model or without modeling anything. We are constrution the information on the plans not the model.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    Neilw
    02-19-2013 01:16 PM in reply to: SDcivil
    I say, slap a slope label on the plan view and add a disclaimer not to scale the drawing. Let the contractor take the liability. :smileywink:
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
