• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Joe-Bouza
    Accepted Solution
    Google Earth units
    187 Views, 8 Replies
    01-22-2013 08:09 AM
    My drawing is set to state plane  and feet. when I import GE the elevations are different that thos reproted on the GE screen. For example at a given location GE reports 538 but the c3d surface  report 164 a factor of 3.28. sounds like a meter thing going on. is this normal? can It be adjusted?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Please use plain text.
    Member
    Re: Google Earth units
    01-22-2013 08:13 AM in reply to: Joe-Bouza
    I've gotten around this by typing UNITS at the command line and setting the "Insertion Units" to Feet.
    *Expert Elite*
    Joe-Bouza
    01-22-2013 08:19 AM in reply to: KenPrzybysz
    Perfect!
    Thanbks Ken
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    Member
    01-22-2013 08:30 AM in reply to: Joe-Bouza
    You're welcome! Trying to start to give back to the boards when I can!
    *Expert Elite*
    Joe-Bouza
    01-22-2013 08:33 AM in reply to: KenPrzybysz
    Got get em!
    Hey you got 1 kudo for 3 post. You'd be heading for Cooperstown with numbers like that :smileywink:
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    01-22-2013 08:35 AM in reply to: Joe-Bouza
    Yes Joe, this is a Feet to Meter thing. There are 3.28 Feet per Meter, just to clarify a tiny bit here!
    *Expert Elite*
    Joe-Bouza
    01-22-2013 08:41 AM in reply to: Sindarin
    Hi Sindarin,
    That much I got. But if GE is saying feet and my c3d says feet other than acad units were unitless why would it come in in meters?
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    01-22-2013 08:44 AM in reply to: Joe-Bouza
    Hey Joe, not much work to do today I see... Instant replies!!! *forget I said that*
    I have had that problem in Civil 3D 2011 as well. If I imported something into my drawing, it would show up in inches, and put itself out way in outer space, but if I copy and pasted it, it would show up properly.
    Both my drawings and units were set up to be the exact same, so I have no clue what happened.
    Under your Toolspace drawing settings, what is your drawing units set up too? That may have something to do with it. Also make sure the "Scale objects inserted from other drawings" is selected.
    Give that a try I guess.
    *Expert Elite*
    Joe-Bouza
    01-22-2013 09:15 AM in reply to: Sindarin
    (I waited a few minutes this time)
    Thankes I see the check boxes that apply. Thats a big help.
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
