• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Accepted Solution
    Getting a "Failed Point Outside Surface" Error While Building a Corridor
    134 Views, 2 Replies
    11-05-2012 09:36 AM
    Hey,
    I'm having problems with Autocad Civil 3d 2012. I'm building a corridor of a curb gutter and sidewalk with a daylight of 2:1 on top of an EG surface. The corridor works for about 3/4 of the length but the last section won't connect the daylight to the existing ground surface. There are multiple sections of the corridor with different assemblies.
    Here is a more detailed error report:
    Type: Error
    Date: 11/5/2012
    Time: 9:15:06 AM
    Source: Roadway
    User: engintern4
    Description: 6+80.00':  Failed
    Point Outside Surface.
    Offset: -7.542'
    Elevation: 85.776'
    Corridor: CURB-GUTTER-SIDEWALK CORRIDOR
    Baseline: Gutter Alignment
    Alignment: Gutter Alignment
    Profile: Gutter Profile
    Assembly: SIDEWALK-CURB-GUTTER-DAYLIGHT
    Assembly Baseline:
    Subassembly Group: Group - (3)
    Local Subassembly Name: DaylightMaxOffset
    Global Subassembly Name: DaylightMaxOffset (Left) - (50)
    Assembly: C:\ProgramData\Autodesk\C3D 2012\enu\C3DStockSubassemblies.dll
    .Net Class: Subassembly.DaylightMaxOffset
    Source: AeccDbMgd
    I get about 33 of these errors each time the corridor rebulds. I'm not sure whats going on, the corridor has targets set for the surface and still won't connect to it.
    Has this happened to anyone else?
    Please use plain text.
    *Pro
    Re: Getting a "Failed Point Outside Surface" Error While Building a Co
    11-05-2012 10:17 AM in reply to: chris112288g
    show us a picture with the ex surface contours and the prop surface contours or corridor model turned on.
    my guess is that the 2:1 is landing past the outter edge of the existing surface and so it is not generating the daylight.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    New Member
    11-05-2012 10:31 AM in reply to: dgordon
    I just figured it out as you replied. There was something wrong with the daylight subassembly. I tried using a different preset subassembly and it fixed the errors.
    Thanks for the reply
