• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Geometry Point Labels - Text Style Issue
    201 Views, 4 Replies
    01-21-2013 07:19 AM
    I am in the process of modifying our current company standards to conform to another set of standards. The main change is switching from "simplex" font style to "Tahoma".
    Simple in theory but problematic in execution, our main alignment label style "GEO-LABL", used for P.O.T, PC, ect. utilizes an underlined reference text object in order to control the length of the line under the call. The base insertion places the call perpendicular to the alignment, when dragged to the left or right it switches to stacked text plan readable. Works like a champ with the "simplex" text style - 1.jpg see attached.
    Now simply changing the font to "Tahoma" - 2.jpg the larger you make the text the larger the gap.
    I am trying to stay away from adding a line for the underline due to the difference in lengths needed when the call gets longer or shorter based on alignment name or stationing.
    Any ideas out there?
    Thanks.
    Bill H.
    Civil 3D 2013 SP 1
    Win 7 Pro 64-Bit - Dell T1600
    Intel Xeon 3.30Ghz
    8Gb RAM
    Civil 3D 2013
    Please use plain text.
    *Expert Elite*
    Re: Geometry Point Labels - Text Style Issue
    01-21-2013 01:15 PM in reply to: dbill2508
    Use a line and attach the start of the line to the bottom left of the text, and attach the end of the line to the bottom right of the text.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Valued Contributor
    ccookusi
    01-22-2013 05:52 AM in reply to: dbill2508
    Do you need to create a "Left" and "Right" style for this to work?
    See images..
    Windows 7 Pro x64
    Civil 3D 2013 (SP1)
    Dell Precision T1650
    i7 3770
    NVIDIA Quadro 2000
    SSD Boot
    12 GB Ram
    *Expert Elite*
    01-22-2013 06:45 AM in reply to: ccookusi
    Are you asking me?
    Possibly, yes.  I guess this would be restricted to "As Composed" and not the "Stacked Text".
    I'm just throwing ideas around (as requested).  Not necessarily fully baked ones.
    01-22-2013 07:51 AM in reply to: troma
    Thanks for the replies. The line idea works for what we need.
    Just stinks that the font change has an adverse effect on the resulting label.
    Intel Xeon 3.30Ghz
    8Gb RAM
    Civil 3D 2013
