• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    General Note - Plot Style of Leader
    154 Views, 4 Replies
    08-15-2012 12:47 PM
    We use STB plot style tables for all of our drawings.  I have several general note styles setup in Civil 3D 2012.  When you pull the note text out so that you have a leader, the leader does not plot per the plot style assigned to the layer that the note is set to display on on the General tab.  It appears as the proper color and freezes with the layer properly, but it plots with the settings of the plot style assigned to layer 0.  Is there a reason that the leaders don't use the plot style setting form the layer it is displayed on????
    Please use plain text.
    Valued Mentor
    Valued Mentor
    sjg
    Re: General Note - Plot Style of Leader
    08-15-2012 12:55 PM in reply to: pcchenard
    Did you check the leader settings, under the dragged state tab
    Steve Goessling
    Land Consultants
    Civil3D 2012 (Service Pack 2.1)
    Windows 7, 64 bit
    Intel i7 2600 @ 3.40Ghz
    16 GB RAM
    Nvidia Quadro 600
    08-15-2012 01:01 PM in reply to: sjg
    Yes, I did.  Everything on that tab is set to BYLAER.  There is no setting for PlotStyle anywhere in the note sytle settings.
    Product Support
    AlmasSuljevic
    08-17-2012 02:13 PM in reply to: pcchenard
    Do you see the same issue if you plot to some other plotter? Does it show correctly on plot preview? How about other drawings-do they plot OK with that STB file.
    In Plot dialog, is "Plot with Plot Styles" checked?
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Autodesk, Inc.
    Please click on "Accept as Solution" if post helped you resolve the issue.
    08-20-2012 07:40 AM in reply to: AlmasSuljevic
    Yes, I see the same issue regardless which plotter I use.
    No, it does not show correctly in the plot preview.
    Yes, "Plot with Plot Styles" is checked in the plot dialogue.
