• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    GreeneSWCD
    First corridor project, help with daylighting
    226 Views, 7 Replies
    04-25-2012 02:04 PM
    I need to design a grassed waterway with a parobolic shape that will be cut down through a field.  I have seven control points that I need to incorporate into the cross section, then the assembly needs to daylight onto the surface.  I've made an assembly, but I can't get it to daylight properly.  I'm using the generic length/width/slope sub-assembly with the generic daylight subassembly at the ends.
    What I done was to first lay down an alignment, then profile that alignment with sampling offsets of 15,-15 on my profil.  From that, I can lay in a proposed centerline using the offsets as my banks.  When I run the corridor, I get errors regarding those offsets for some reason?  Are the offsets the problem?
    I want the daylight segment to either come up to the surface on a 10:1 whenever possible so water gets into the waterway nice and gently.  If the daylight can't possibly tie in with positive slope, I want the daylight to go down to the surface on a 3:1 fill.  Am I using the correct subassembly for this?
    I work in a Soil and Water Conservation District, so I'm no professional engineer, so be kind and basic.  Thanks.
    Please use plain text.
    Product Support
    Re: First corridor project, help with daylighting
    04-27-2012 08:08 AM in reply to: GreeneSWCD
    Just judging from your description, it seems that the conditional subassemblies may be what you are looking for:
    http://docs.autodesk.com/CIV3D/2013/ENU/filesCSH/GUID-BCAD3E52-544A-47E7-A9F4-BB114DF8CAC3.htm
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Being Civil
    Being Civil Twitter
    Being Civil Facebook
    sboon
    04-27-2012 03:04 PM in reply to: GreeneSWCD
    Trying to ensure that I understand what you have described:
    • You have seven control points which define the typical cross section - correct?  A sketch showing what they look like would help.
    • You are sampling the existing surface at 15' offset, and then using those offset profiles in your corridor targets somehow.  Are you intending that the daylight should always tie in at a 15' offset regardless of whether it's cut or fill?
    • If you want to tie into a specific offset while also maintaining a specified cut or fill slope then that is probably possible, but you will likely need to use conditional cut or fill subs, as well as others.
    Need more info - a sketch would be useful.
    GreeneSWCD
    05-01-2012 01:41 PM in reply to: sboon
    Sorry for the slow responses, I've been on vacation.
    I hope this quick sketch shows what I'm trying to reproduce in my corridor.  You'll see on one end that I need to fill (3:1 both sides) and the other end needs to blend to existing with positive slope (10:1 works, but so does any positive number).
    Jeremiah
    GreeneSWCD
    05-01-2012 01:43 PM in reply to: GreeneSWCD
    There is actually a typo in my quick sketch.  The depths from left to right need to be 0.0, 0.50, 0.75,1.0, 0.75, 0.50, 0.0.
    Thanks.
    Product Support
    05-03-2012 12:15 PM in reply to: GreeneSWCD
    If I am understanding you correctly, I believe you could overrride the daylight and get the desired results.
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Being Civil
    Being Civil Twitter
    GreeneSWCD
    05-03-2012 01:24 PM in reply to: SethHall
    Ok, how do I override the daylight?
    I just need to learn how to put together the assembly for a 30' top width waterway.  I can use that one as a template to do any other top width.  Which sub assemblies should I be using?
    Thanks for all your help, especially since the above reads like a federal govt spec, and that's never a good thing...
    Product Support
    05-04-2012 07:23 AM in reply to: GreeneSWCD
    You can override the daylight slopes from the section editor>parameter editor:
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Being Civil
    Being Civil Twitter
