• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Accepted Solution
    Filtering Grade Break Labels
    711 Views, 13 Replies
    05-18-2012 12:55 PM
    I've got a drawing in which the existing ground is so jaggedy that I've got way too many grade breaks (see the attached image).  I know I can use the weeding and eliminate the labels every 50 feet, or so, along the profile.  But I need to have the ability to only show a specific grade break range.  For instance, I'd like for my profile only to display grade breaks between 0% and 2% and not to display anything above 2%. I've tried making an expression, but have been hitting brick walls.  I also know I can manually (use the CTRL + click) select the specific labels that I don't want and erase them, but I've got lots of these labels.  Is there anyone out there (much more savvy at this than I) who knows of a LISP routine or an expression that can accomplish this?
    Please use plain text.
    *Expert Elite*
    Re: Filtering Grade Break Labels
    05-18-2012 02:13 PM in reply to: PorterCAD
    I learned this just the other day, thanks to Jeff_M.
    IF(ABS({Grade Change})<=2,0.10,0)
    Then, in the label style, instead of using a fixed text height, use the expression name. It will be available in the list where you give text height for the components.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    *Expert Elite*
    Joe-Bouza
    05-18-2012 02:29 PM in reply to: PorterCAD
    Thats what I call a golden nugget :smileywink:
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Valued Contributor
    05-18-2012 02:34 PM in reply to: tcorey
    Tim,
    Amazing!  I was using the wrong set of codes for the expression and was attempting to use it in the completely wrong area.  Thank you very much!
    One more question, does your buddy Jeff_M also have a the code for filtering out the percent grades along the profile. I'll play with the expressions again but thoght I'd ask anyway.
    Regardless, thanks for the response.
    Jason
    *Expert Elite*
    05-18-2012 04:28 PM in reply to: PorterCAD
    To filter the label by slope, make an expression under Profile-->Label Styles-->Line.
    IF(ABS({Tangent Grade})<=0.02,0.1,0)
    Use this expression as the text height in the label style. To filter on different value than <= 2%, adjust the first number, where I put 0.02. Four and a half percent would be 0.045, etc.
    Tim Corey, Owner
    Redding, CA
    *Expert Elite*
    johnm
    05-19-2012 08:22 AM in reply to: PorterCAD
    The expression is the best way to filter the grade labels by percent but there is another way to simply reduce the number of labels. You all probalby know this but just in case,
    In the profile properties dialog, bands tab, add a label weeding factor to the band. This will not filter by slope but if you just want fewer labels this tool is provided.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    Valued Contributor
    05-21-2012 11:09 AM in reply to: tcorey
    Tim,
    You solution worked GREAT! ! ! !    After creating the expression, I went into my "percent grade" label style.  I verifired that the expression was set for Tangent Grade.  For the text height i set the value to be the name of the expression.  In your expression code I had to change the text height value form:
    • IF(ABS({Tangent Grade})<=0.02,0.1,0)
      to
    • IF(ABS({Tangent Grade})<=0.02,0.01,0)
    After that was set my labels are filtered perfectly and the text height is correct.  Not sure why the text height must be set to 0.01 in order for the text to appear 0.1 in heigt, but I don't care.  It works.
    Thanks for all your input,.
    Jason
    New Member
    06-19-2012 08:12 AM in reply to: PorterCAD
    This works great!
    But how would I show something other than 0%-2% like 1%-5% or something like that.
    *Expert Elite*
    06-19-2012 10:02 AM in reply to: christopheram85
    This is for showing only 1% thru 5%:
    IF(ABS({Tangent Grade})>=0.01,(IF(ABS({Tangent Grade})<=0.05,0.01,0)),0)
    Adjust the 0.01 to work with your text size. For imperial drawings, if your normal text height in the style composer is 0.10", then this should be 0.10/12.
    *Expert Elite*
    06-19-2012 10:57 AM in reply to: PorterCAD
    C'mon, Jeff. I was getting all that credit for your solution and now you stick your nose in here...:mansad:
    Tim Corey, Owner
    Redding, CA
