• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Few Simple Questions??
    59 Views, 5 Replies
    04-30-2005 01:36 PM
    we're converting from Field survey to CD3 and am finding the learing curve a little heavy at time. So I have a couple question I hope can be easily answered
    1: in Field survey they have a command that will draw a curve between 2 points at a specific radius..you enter your two end points and give it a radius and it draws the curve....is there a simiilar command in CD3/LD
    2: Just got a large layer list from a client. He send us a DWT and a XLS file.....the DWT file opens but has all his setting for the drawing inplace and being new to CD3....is there a easy way to just import just the Layer file into a new drawing and go from there?
    Thanks for any help!!!
    Chris
    Please use plain text.
    *Don Reichle
    Re: Few Simple Questions??
    04-30-2005 01:54 PM in reply to: CHRISL76
    Hey Chris;
    The answer to the 2nd question is fairly
    easy to handle - do a Save As from their DWT into a DWG. You can then use Design
    Center to transfer layers from that fresh DWG.
    Now for the 1st question:
    If you've got Civil 3D 2006, you should have
    received LDT2006; or if you've acquired the 2005 version, Land should have
    accompanied it. I'm not familiar with that particular command you're looking
    for, but there are a number of Curve commands on the LDT Menu Palette. Once you
    get LDT Open look for the Lines/Curves pulldown (see below):
    [img src="@78990"]
    Do those look familiar?
    HTH
    Don Reichle
    "King Of
    Work-Arounds"
    "The only thing worse
    than training your staff,
    and
    having them leave is -
    not training your staff,
    and having them
    stay."
    Courtesy Graphics Solution
    Providers
    LDT3/CD3
    IntelP4-2.4< BR>1GB
    RAM
    Intel 64MB
    we're
    answered
    CD3/LD
    Thanks for any
    help!!!
    Chris
    Active Member
    04-30-2005 02:16 PM in reply to: CHRISL76
    I have played with the curve pulldowns as you showed, but I still have not been able to get it to draw the right kind of curve..for example....I draw a lot survey where the front of the lot is on a 150' radius curve....I draw the other 3 sides of the rectangular lot. What command will give the ability to draw a curve from one lot corner to the other lot corner with 150' radius...in field survey it askes you for the PC, radius, and the chord....
    Thanks....I got the layer transfer to work...
    *Don Reichle
    04-30-2005 03:28 PM in reply to: CHRISL76
    Hey Chris;
    Field Survey has not been integrated into Civil 3D as of the current
    version, so to get the functionality you're looking for you'll still need to
    use that for the interim. Or Land, as I was able to get the Lines/Curves
    "From End of Object" to work as you had explained the parameters you were
    looking for. I used an existing arc, and indicated which end I wanted to
    start from; gave it the radius and delta; and the arc was drawn. This was in
    my version, LDT3.
    It was pointed out recently that FS 2006 bears a strong resemblance to Civil
    3D, so that may be an indicator of things to come. When is a different
    story. Being that its the weekend, you may get a better answer on Monday.
    Don Reichle
    "King Of Work-Arounds"
    and having them leave is -
    and having them stay."
    Courtesy Graphics Solution Providers
    LDT3/CD3
    IntelP4-2.4
    1GB RAM
    Intel 64MB
    wrote in message news:4831397@discussion.autodesk.com...
    *Laurie Comerford
    04-30-2005 03:31 PM in reply to: CHRISL76
    Hi Chris,
    The AutoCAD ARC command allows you to do this.
    The Help files till you how, but essentially it is start the command - pick
    the first point, type E to select the end and then R to enter the radius.
    Laurie Comerford
    CADApps
    www.cadapps.com.au
    wrote in message news:4831394@discussion.autodesk.com...
    answered
    Chris
    *wfb
    05-01-2005 05:59 AM in reply to: CHRISL76
    Just use the fillet command. Fillet -> Radius = 150
