• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Feature line colours
    59 Views, 3 Replies
    11-29-2012 03:58 AM
    Hi All,
    When I insert featurelines from one drawing into another they lose their colour properties even though they are ‘bylayer’. i.e each feature line is a different colour but once inserted into new drawing they are all blue. If I click on the feature line it will show the correct colour in the properties block but not displaying as that colour.
    Anyone know the reason for this and how I could stop it happening?
    Please use plain text.
    Valued Mentor
    Re: Feature line colours
    11-29-2012 05:43 AM in reply to: onedayiwillbeaguru
    When you use the term insert, are you inserting them as a block. If so explode it and they should go to the correct layer.
    *Expert Elite*
    11-29-2012 08:01 AM in reply to: onedayiwillbeaguru
    Check your feature line styles.
    Let's say your Feature Line Style is called MyStyle in both drawings, it might set the lines to Bylayer in one drawing and to Blue in the other. See the Display tab of the Feature Line Style Editor.
    Don't explode the feature lines unless you absolutely must.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    *Expert Elite*
    11-29-2012 10:10 AM in reply to: tcorey
    I think the explode remark can be explained thusly:
    If your feature lines are individual feature lines, and say they are feature lines in the properties box when selected: don't explode the feature lines.
    If you inserted feature lines as a block and they are still in that block, all together as one object that says it is a block in the properties box: explode the block.
    If the feature line style is set to layer 0 and colour ByLayer, does the feature line take the colour of it's Object layer?  I'm not sure, but that's another possibility to look into.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
