• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D
    *CivilEITGuy
    Feature Lines
    83 Views, 2 Replies
    12-04-2008 08:35 PM
    In LDT I would create 3D Polys (by Elevation) and select ".G" at the prompt
    for points to select the AEC point object. That way the 3D poly will
    automatically grasp the elevation, then I would type ".G" again to exit the
    prompt. Is there a way to do this with feature lines in 3d? When I draw a
    feature line and type .G or .P, nothing happens. Or do the points need to
    be at actual elvations?
    Thanks in advance.
    Please use plain text.
    Active Contributor
    Re: Feature Lines
    12-05-2008 01:23 AM in reply to: *CivilEITGuy
    In Civil 3D you should use the Transparent Commands; for example '_PO for points. It is more convenient to turn on the Transparent Commands Toolbar and use the transparent commands from those tools.
    *Pro
    Re: Feature Lines
    12-05-2008 05:16 AM in reply to: *CivilEITGuy
    Feature lines have their own set of tools in a toolbar. Once you bring this toolbar up and see what is in it, you should have your answer.
    Dan
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
