• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Feature Lines
    73 Views, 3 Replies
    05-26-2005 10:28 AM
    I have modeled a corridor, and now I want to export a feature line, but I can't seem to get them to generate!?!?
    Suggestions?
    Erik Swanson
    Project Manager
    David E. Ross Associates
    Please use plain text.
    *Daniel Philbrick
    Re: Feature Lines
    05-26-2005 10:52 AM in reply to: Swanzo
    Erik,
    Are you finding that you cannot select the feature line? Does the command
    Export > Corridor Feature line as polyline work? Does the Corridor have
    multiple baselines?
    Dan
    wrote in message news:4857710@discussion.autodesk.com...
    Suggestions?
    Erik Swanson
    Project Manager
    Active Contributor
    Re: Feature Lines
    05-26-2005 11:48 AM in reply to: Swanzo
    Background:
    I have a corridor with a cul-de-sac at the low point. Since I want to keep the vertical alignment of the centerline, I used the basic lane transition to stretch out to the curbline. I have also defined an alignment along the c-d-s curbline.I want to export the feature line @ ETW as the vertical alignment component (profile) for the curbline - then attach an assembly for the curb/sidewalk around the c-d-s. I added the ETW feature line in the Surfaces tab of the Corridor properties dialog box.
    When I rebuild the surface, I can't select the feature line...
    Distinguished Contributor
    Re: Feature Lines
    05-27-2005 05:38 AM in reply to: Swanzo
    Have you exported the surface using the "Corridor> Export" tool. If so, turn off the layer with the exported surface on it and try to select the feature line. I ran into this yesterday when trying to create a "Render Only" boundary on a corridor that I had just exported the surface from. It seems that the surface breakline was on top of the corridor feature line and when I tried to select the feature line I got a command line message that said "No feature line selected". I deleted the surface from the surface collection then it worked fine. I would assume that turning off the layer would save you having to delete the surface.
