• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Feature Line Label Arrows
    317 Views, 5 Replies
    06-25-2007 04:53 PM
    (Civil3D 2008)
    Is it possible to label feature lines with the grade and a direction arrow so that the arrow is pointing downhill ie from high point to low point?
    At present, the arrows seem to point in the direction in which the feature line was drawn, with the label text being negative or positive to indicate direction of fall.
    Please use plain text.
    *Jeff Mishler
    Re: Feature Line Label Arrows
    06-25-2007 05:27 PM in reply to: AGBell
    In the "Grading Best Practices" White Paper it shows how to make this style.
    Crazy thing is I JUST read it and saw your message within 30 seconds.....
    http://civilcommunity.autodesk.com/blogs/blog/4/blogpost/5893/
    wrote in message news:5638052@discussion.autodesk.com...
    (Civil3D 2008)
    direction of fall.
    06-25-2007 06:16 PM in reply to: AGBell
    That was fast jeff!
    And it's just what I was looking for, however... when I go into the label style composer I can't select "Grade Check" in the rotation angle box of the arrow component. All I can do with it is to type in an angle or select one on-screen.
    Any clues?
    *Jeff Mishler
    06-26-2007 09:27 AM in reply to: AGBell
    The dwt Template file "_AutoCAD Civil 3D (Imperial) NCS Extended" includes
    the "Grade Check" Expression. IOW, if you don't have the option for the
    slope, you will need to create your own Expression. Here is the formula
    needed:
    IF({General Segment Grade}<0,0,pi)
    wrote in message news:5638094@discussion.autodesk.com...
    That was fast jeff!
    on-screen.
    Any clues?
    06-27-2007 01:11 AM in reply to: AGBell
    Thank you. Works like a charm.
    I can see Expressions require some serious looking-into.
    04-27-2011 05:19 PM in reply to: *Jeff Mishler
    Thanks this is a real life saver. I'm doing a rather large parking lot for a college and labeling gutterline slopes manually would be brutal and a waste of valuable budget time.
