• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    rkmcswain
    Fatal Error when using OSNAP in profile view (2011)
    126 Views, 2 Replies
    09-27-2011 10:05 AM
    C3D2011 - current updates.  Running object snaps are disabled.
    When working inside a profile view, using any command (regular AutoCAD command or a C3D command)... if I enable an object snap, and then move the cursor so that it hovers over the intersection of a grid line and the profile line - I get a fatal error.... every time.
    See http://cadpanacea.com/tmp/sample/profileviewfatalerror.swf for an animation of this.
    Anyone else seen this?
    Please use plain text.
    Re: Fatal Error when using OSNAP in profile view (2011)
    09-27-2011 11:13 AM in reply to: rkmcswain
    R.K.
    If you like, I would be glad to run it through my computer to perhaps see if it is drawing specific, etc.  I still have 2011 loaded.
    Bill
    Product Support
    AlmasSuljevic
    09-27-2011 11:19 AM in reply to: rkmcswain
    I tried using one of the tutorial drawings (Profile-3B.dwg) on machines running Civil 3D 2011 Update 2 and Update 1 and did not see the issue.  Can you post your drawing or try tutorial DWG again?
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Please click on "Accept as Solution" if post helped you resolve the issue.
